Problem with VoIP lines not registering
Discussion in '3CX Phone System - General' started by Ralph, Aug 18, 2007.
  1. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good morning,
    I seem to have a chronic problem with my VoIP lines unregistering and not re-registering once a week. It appears that every Saturday around 11am all my VoIP lines become unregistered. They then will not register for several hours. Then all of a sudden they all register.
    Wireshark and the logs show 3CX attempting to register but the VoIP provider states that they aren't recieving the registration requests.
    I am able to register the lines just fine from the same subnet using X-Lite during this same period of time.
    Anyone have any ideas as to what might be going on? Network traffic durring this time is minimal and I have turned QOS on and off to see if there is somthing there causing problems (no effect). I have also restarted the 3CX server. Changed the proxy settings, DNS is working properly, etc.
  2. Ralph
    Ralph Member
    Jun 28, 2007
    417
    More info
    Well one of the techs at Broadvoice said that the pbx showed that it was registered and then errored out as a 401 (unauthorized).
    I have checked and re-entered passwords, and user names multiple times. Occasionally, if I switch BroadVoice proxies the 3cx will register but now it is disconnects 5 minutes later and can't re-register again.
    According to BroadVoice if you get 3 unauthorized errors in a row your IP is restriced from their system for an hour. :roll: So what may be happening is the line errors out and then after the pbx tries to re-register 3 times it locks my IP out for an hour.
    Tech support at BroadVoice is unable to tell me why the lines are erroring out. Basically all they can tell me is that the lines aren't registered,
    Which of course is extemely helpful :roll:
    Any ideas? Anyone else having a problem with BroadVoice??
  3. mfaster
    Jun 19, 2007
    21
    Problems with Broadvoice Registration
    I just started using Broadvoice on 27-08-07 and have been seeing the broadvoice line register and unregister..it will drop a call when the unregister happens....here's what I see in my log:
    13:23:24.250|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:2474 by server 192.245.12.229
    13:23:24.265|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:23:24.265|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:23:24.312|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1426 by server 64.69.76.23
    13:23:24.406|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:23:24.406|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:23:24.703|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    13:23:24.765|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    13:35:21.046|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:21.046|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:21.359|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:21.359|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:22.296|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:22.296|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:22.609|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:22.609|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:22.921|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:22.921|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:22.921|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 120 sec.
    13:35:23.546|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:23.546|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:23.859|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:23.859|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:25.734|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:25.734|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:27.921|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:27.921|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:29.796|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:29.796|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:32.609|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:32.609|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:33.859|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:33.859|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:34.796|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:34.796|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:35.421|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:35.421|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:35:37.234|.\CallStrategies.cpp(264)|Log2|CallManager|StratLink::eek:nHangUp:[CM104001] Call(38): Ext.131 hung up call; cause: BYE; from IP:192.168.64.240
    13:35:39.421|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:35:39.421|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:36:03.078|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(43): Incoming call from 131 (Ext.131) to sip:*18664693239@192.168.64.11
    13:36:09.250|.\SLServer.cpp(287)|Error1|MediaServer|MediaServerReporting::STUN:[MS101003] Call(43) Ln:10004@Broadvoice: Possible firewall problem. Address mapping failed on STUN server 64.69.76.23:3478 for local address ":9000"
    13:36:19.937|.\CallStrategies.cpp(770)|Log2|CallManager|StratInOut::eek:nHangUp:[CM104007] Call(43): Call from Ext.131 to 18664693239 has been terminated by Ext.131; cause: CANCEL; from IP:192.168.64.240
    13:37:55.359|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 240 sec.
    13:42:27.859|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 360 sec.
    13:43:27.593|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 192.245.12.229
    13:43:30.656|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 64.69.76.23
    13:43:30.765|.\StunClient.cpp(67)|Log2|STUN|StunClient::process:[CM115001] Send initial STUN request to 192.245.12.229
    13:43:33.828|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 192.245.12.229
    13:43:36.890|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 64.69.76.23
    13:43:37.000|.\StunClient.cpp(67)|Log2|STUN|StunClient::process:[CM115001] Send initial STUN request to 192.245.12.229
    13:43:40.062|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 192.245.12.229
    13:43:43.125|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 64.69.76.23
    13:43:43.234|.\StunClient.cpp(67)|Log2|STUN|StunClient::process:[CM115001] Send initial STUN request to 192.245.12.229
    13:43:46.296|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 192.245.12.229
    13:43:49.359|.\StunClient.cpp(94)|Error1|STUN|StunClient::process:[CM215001] STUN failed to resolve external IP using server 64.69.76.23
    13:43:49.359|.\CallMgr.cpp(308)|Error1|CallManager|CallMgr::failResolveExtIp:[CM200001] Failed to resolve external IP!
    13:43:49.421|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:43:49.421|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:44:21.765|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:44:21.765|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:44:21.765|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 120 sec.
    13:45:21.218|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:21.218|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:21.593|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:21.593|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:21.609|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:21.609|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:21.640|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:21.640|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:22.640|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:22.640|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:22.656|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:22.656|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:22.671|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:22.671|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:23.062|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:23.062|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:23.078|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:23.078|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:23.109|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:23.109|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:23.765|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:23.765|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:24.109|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:24.109|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:26.015|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:26.015|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:28.250|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:28.250|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:28.265|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:28.265|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:30.171|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:30.171|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:32.703|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:32.703|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:33.984|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:33.984|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:34.953|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:34.953|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:35.609|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:35.609|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:39.703|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:45:39.703|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:45:53.468|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:53.468|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:53.781|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:53.781|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:54.718|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:54.718|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:55.031|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:55.031|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:55.343|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:55.343|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:55.968|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:55.968|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:56.281|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:56.281|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:45:58.156|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:45:58.156|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:00.656|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:46:00.656|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:02.531|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:46:02.531|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:05.031|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:46:05.031|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:06.281|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:46:06.281|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:07.218|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:46:07.218|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:07.843|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:46:07.843|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:46:11.906|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 120 sec.
    13:48:44.281|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 240 sec.
    13:53:16.562|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 360 sec.
    13:54:21.906|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:54:21.906|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:54:54.109|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:54:54.109|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:54:54.109|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 120 sec.
    13:55:53.828|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:53.828|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:53.843|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:53.843|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:54.218|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:54.218|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:54.234|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:54.234|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:54.265|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:54.265|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:54.921|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:54.921|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:55.281|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:55.281|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:55.296|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:55.296|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:55.671|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:55.671|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:55.687|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:55.687|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:55.703|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:55.718|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:56.390|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:56.390|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:56.406|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:56.406|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:55:58.312|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:55:58.312|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:00.859|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:00.859|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:00.875|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:00.875|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:02.781|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:02.781|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:05.312|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:05.312|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:06.593|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:06.593|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:07.250|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:07.250|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:07.906|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    13:56:07.906|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    13:56:26.093|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:26.093|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:26.406|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:26.406|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:27.031|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:27.031|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:27.656|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:27.656|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:27.968|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:27.968|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:28.593|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:28.593|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:30.468|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:30.468|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:33.281|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:33.281|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:35.156|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:35.156|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:37.656|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:37.656|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:38.906|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:38.906|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:39.531|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Request Timeout
    13:56:39.531|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    13:56:40.156|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 120 sec.
    13:59:12.703|.\Registrar.cpp(477)|Log2|Registrar|ClientRegs::eek:nRequestRetry:[CM113008] Registration attempt for Ln:10004@Broadvoice is scheduled in 240 sec.
    14:03:18.453|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:03:49.484|.\StunClient.cpp(67)|Log2|STUN|StunClient::process:[CM115001] Send initial STUN request to 192.245.12.229
    14:03:49.515|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1561 by server 192.245.12.229
    14:03:49.546|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:03:49.546|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:03:49.578|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1695 by server 64.69.76.23
    14:03:49.593|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:03:49.593|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:03:49.937|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:03:50.000|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:04:54.281|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:04:54.281|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:04:54.750|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:26.421|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:26.421|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:26.437|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:26.437|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:26.453|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:26.453|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:26.625|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:26.625|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:26.656|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:26.656|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:26.671|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:26.671|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:26.812|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:26.828|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:26.843|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:26.859|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:26.921|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:27.250|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:27.250|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:27.750|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:27.750|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:27.750|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:27.765|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:27.765|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:28.015|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:28.015|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:28.031|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:28.031|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:28.062|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:28.062|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:28.203|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:28.218|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:28.234|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:28.421|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:28.765|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:28.765|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:28.781|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:28.781|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:29.125|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:29.187|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:30.765|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:30.765|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:31.203|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:33.421|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:33.421|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:33.437|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:33.437|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:33.781|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:33.843|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:35.421|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:35.421|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:35.859|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:37.750|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:37.750|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:38.203|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:39.156|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:39.156|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:39.578|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:06:39.578|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:06:39.578|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:06:40.046|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:10:14.812|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:4084040052@sip.broadvoice.com has failed; reason=Internal Server Error
    14:10:14.812|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
    14:14:42.734|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(44): Incoming call from 129 (Ext.129) to sip:110@192.168.64.11
    14:14:42.906|.\CallConf.cpp(178)|Log2|CallControl|CallConf::eek:nProvisional:[CM103003] Call(44): Ext.110 is ringing
    14:14:49.828|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(44): Created audio channel for Ext.129 :)24416) with third party :)21792)
    14:14:49.828|.\CallStrategies.cpp(705)|Log2|CallManager|StratInOut::eek:nConnected:[CM104005] Call(44): Setup completed for call from Ext.129 to Ext.110
    14:14:49.828|.\Call.cpp(266)|Log2|CallControl|CallLegImpl::eek:nConnected:[CM103001] Call(44): Created audio channel for Ext.110 :)21792) with third party :)24416)
    14:15:12.609|.\CallStrategies.cpp(264)|Log2|CallManager|StratLink::eek:nHangUp:[CM104001] Call(44): Ext.129 hung up call; cause: BYE; from IP:192.168.64.210
    14:16:12.687|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:2966 by server 192.245.12.229
    14:16:12.734|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:2090 by server 64.69.76.23
    14:16:12.734|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:16:12.734|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:16:12.765|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:16:12.765|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:16:13.078|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:16:13.703|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:20:15.156|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:20:15.156|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:20:15.609|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:26:12.921|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1640 by server 192.245.12.229
    14:26:12.953|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:26:12.953|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:26:12.984|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:3002 by server 64.69.76.23
    14:26:13.000|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:26:13.000|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:26:13.343|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:26:13.390|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:36:13.218|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1564 by server 192.245.12.229
    14:36:13.281|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1456 by server 64.69.76.23
    14:36:13.281|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:36:13.281|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:36:13.312|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:36:13.312|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:36:13.687|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:36:13.750|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:46:13.562|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:2011 by server 192.245.12.229
    14:46:13.578|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:46:13.578|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:46:13.625|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1447 by server 64.69.76.23
    14:46:13.640|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:46:13.640|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:46:13.984|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:46:14.046|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
    14:56:13.921|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:2424 by server 192.245.12.229
    14:56:13.968|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=76.227.67.238:1217 by server 64.69.76.23
    14:56:13.984|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:56:13.984|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:56:14.015|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10004' device='Broadvoice'
    14:56:14.015|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "408-383-9200"<sip:4084040052@sip.broadvoice.com>
    14:56:14.390|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:4084040052@sip.broadvoice.com is successful
  4. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Steady......
    This part of the logs looks very familar:
    No solution yet. The techs at Broadvoice tell me that I need to call them when it happens and then when I call them when it happens on Saturday they tell me they don't have access to the logs on the weekend and I need to call back on Monday :shock: Its like the song that never ends :roll:
    Just so you know..I may go postal around 11:00 am on Saturday when it happens again :twisted:
    [/quote]
  5. mfaster
    Jun 19, 2007
    21
    Techs at Broadvoice
    uh...from my brief encounters and what I read on other boards..."tech at Broadvoice" , "customer service" et al......all oxymorons.....
  6. Ralph
    Ralph Member
    Jun 28, 2007
    417
    GRRRRR!!!!
    Grrrrrrr!!!!!
  7. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    What if you restart 3cx when that happens, do lines register then?
    Becouse if that happens there is a "fix" for it.
    Cheers
  8. mfaster
    Jun 19, 2007
    21
    Lines do not immediately rergister after a restart of 3CX
    The lines do not re-register after a restart of 3CX. I suspect although have not researched, tested or confirmed that the registration problems have to do with STUN client problems, involving FW ports, etc. I need to find out what STUN server broadvoice is trying to use. I used the template to configure Broadvoice and stun server setting was greyed out...so not sure if it uses the same servers as set for 3CX in general.
  9. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Hi Mfaster
    It is irrelevant which Stun servers you use - all STUNS provide the same service - your public or external IP address. You do not have to use Broadvoice's own STUN server - Thats why it was greyed out in the Template. Trust me - the template works as is. the problem is not there.
    Broadvoice work different than other VoIP providers. In the sense that they have many register/reregister/unregister procedures that other VoIP providers do not emphasise on.
    One that comes to mind is the issue of Multiple registrations. If they see that a Voip line issued to a person is registered on one IP x.x.x.x and you move your PBX, or you would like to physically change location, take your laptop, install the voip line there and register etc on IP y.y.y.y, the broadvoice will lock you up. It will give you a vague error. You have to first unregister the first line, then wait for 30 minutes (because even if the line is unregistered on our PBX, it will still remain registered for the next 30 minutes - in fact you may still receive calls even if the lamp is red on the 3CX PBX. A Broadvoice line sends a registration every 30 minutes. Now if there is no line to issue a registration request, then you will manage to unregister the VoIP line. Then you can register it in another place or another pc or IP. Never register a Broadvoice Voip a second time while the first line is registered because it will complain. And these are the types of complains it gives. I think that you have multiple registrations of the same Voip Line, of course I may be wrong... ... Keep me posted on this one.
    Another is this that was mentionned in this post - a 1hr lockdown. I imagined myself watching Prison Break series :lol:
    In comparison, other Voip providers allow multiple registrations - some unregister the first and accept always the latter registration wherever it is, others allow 2 registrations and may ring at both places until a timeout expires and one unregisters. There are various procedures - not everyone works the same.
  10. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Mfaster
    I have also noted multiple STUN server requests. If you specify Stun server in the General settings it is enough. So not specify STUN in the templates as well seperately for the Voip providers. I am just telling you how our test broadvoice Voip lines register
    But from this point on (after the 1hr lockdown)
    Everything went back to normal right? STUN resolved using counterpath's STUN server and Broadvoice registered. Or am I getting it wrong?
  11. mfaster
    Jun 19, 2007
    21
    Registration problems fixed ro better
    I had 2 stun servers configured in the general settings...I removed the secondary and the registration problems with Boradvoice seem to have improved significantly...ie less failures...
    at least so far...no help what so ever from Broadvoice "technical Support" they refused any help because I am BYOD bring you own device ie running 3cx.
    nicky i agree that which stun server is used should be irrelevant...as long as it works...I notice I get better results with STUN servers nearby..ie in US.
  12. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Yes Mfaster. You could use a STUN closest to you. If you want I have an application that may interest you. It is called WINSTUN. Have you ever heard of it? You input Stun server (the default that comes in the input field of this program is larry.gloo.net.) If you ping it it is alive. IP is 209.133.58.35.
    You have an option to RUN TEST and immediately it gives you
    1) what type of NAT you are behind
    2) whether Voip will work with STUN or NOT
    3) Port nos info (BASIC)
    4) And Stun Resolved Public IP address.
    Google Winstun. Its from Sourceforge.net. You may like it.
