problem?
Discussion in '3CX Phone System - General' started by tmvngocdung42, Apr 4, 2018.
  1. tmvngocdung42
    Apr 4, 2018
    Good morning all.
    I just installed 3CX on a small server for 10 extensions on site for internal use only (simple install). Works awesome clear voice and easy to setup.
    Suddenly and randomly - some phones starts ringing. Is their any way I can avoid this issue? I am not talking about the ring goes on after a phone authenticates to the VoIP server.
    And lastly all phones (grand stream 1625) remains with a sign of don't disturb, I mean an icon with a phone and a slash in the center.
    Can someone here please help me with the 1st and 2nd problem. Would be greatly appreciated.
    Best.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    764
    117
    What does the activity log show when this happens? You will probably need to change the logging to verbose first. If you don't see anything in the logs when this happens when you might be getting ghost calls.
  3. leejor
    10,442
    235
    You need to verify if this is a set issue, a 3CX issue, or it's being caused by someone outside your network.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,891
    321
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,063
    57
    From within the phone interface, there is a setting that indicates "Accept calls from SIP proxy only" or words to that effect. Enable this to prevent "ghost" calls.
