Problems 3cx on iphone 10
Discussion in 'iOS' started by verweijen, Apr 17, 2018.
  1. verweijen
    Oct 10, 2016
    Hello ,
    I have some problems with my iphone 10 and 3cx.
    Most of the time the app doesn't work.
    its registered but the calls are not comming in on the app,
    or when the calls come in it takes a very long time to ring.
    When i register the account on another iphone (7) or on an android the app works fine.
    Are there more people that are having problems with the 3cx on an iphone 10.
    (The iphone 10 is working on the latest firmware , as even the 3CX is working on the latest firmware)
  2. Faserm
    Apr 4, 2018
    9
    Re-register.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    @verweijen
    I'm not aware of any iPhoneX-specific issues with the iOS client, apart from some minor UI tweaks we just made in the latest 15.5.14.x beta - right these days I've been in chat with some of our customers who are using it and they had no complaints.
    What's the version of your iOS client (Settings/About)? Are you member of our Beta program so you can try the latest 15.5.14?
  4. Shawn
    Shawn New Member
    Feb 2, 2017
    114
    how do you become a member of the beta program for the iOS client?
    I'm still having the same issues as this thread
    https://www.3cx.com/community/threads/ios-client-does-not-ring-unless-app-is-in-focus.54058/
    and would like to try the beta version to see if it makes any difference. my installation is simple with nothing unusual so i am a bit baffled as to why android clients work ok (for the most part) and iOS clients do not ring on inbound calls when the app is not in focus. chat works fine regardless of the status of the client
  5. Vali_3CX
    Dec 12, 2008
    1,479
    67
  6. Shawn
    Shawn New Member
    Feb 2, 2017
    114
    thank you vali. since my other thread is closed, i'll post my solution to the iOS push issue here. I did 3 things and am not 100% sure which one fixed the push issue but I think opening port 443 was it. The 3 things were:
    1. opened outbound port 443 on the 3cx server (some research and found that apparently 3CX contacts APSN via 443 to initiate a push notification)
    2. also opened outbound TCP 2195-2196 according to the 3CX firewall config guide
    3. downloaded new iOS certificate on the 3CX updates
    push is now working on all of our iOS clients.
  7. Vali_3CX
    Dec 12, 2008
    1,479
    67
    What's still unclear for me is why, from all your iPhones, ONLY the X model didn't work? This is what I understood, that for only this particular model the push is not working, am I correct?
