Problems registering after updating
Discussion in '3CX Phone System - General' started by css, Jan 25, 2008.
  1. css
    css
    Aug 15, 2007
    21
    I currently update to version 5.0.379
    I use SPA 3000
    After I did the update none of my extension nor my phone lines would register. Then I tried calling one extension from another and I got a busy signal. Then I decided I would switch my logging level. After rebooting from that the 2 ext I called between and one phone line were registered. I am unable to get any thing else to register here is my log.
    19:25:32.109 ListenConnect SL: connected phonesystem:0/PHPExtension_0 at [phonesystem]/PHPExtension_0
    19:25:22.031 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.4:5100;user=phone
    19:25:21.593 ExtnCfg::updateContact [CM504001]: Ext.115: new contact is registered. Contact(s): [sip:115@192.168.1.115:5060/115]
    19:25:21.578 ExtnCfg::updateContact [CM504001]: Ext.203: new contact is registered. Contact(s): [sip:203@192.168.1.203:5060/203]
    19:25:20.937 StunClient::process [CM506002]: Resolved SIP external IP:port (64.212.47.248:5060) on Transport 192.168.1.4:5060
    19:25:20.656 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.4:5060
    19:25:19.687 LineMgr::eek:nRegUpdAor Registered line: L:2165(2165)
    19:25:19.687 CallMgr::eek:nAddIPs IP(s) added:[192.168.1.4]
    19:25:15.468 FaxCfg::updateContact [CM504009]: Fax Service: changed contact to sip:888@192.168.1.4:5100;user=phone
    19:25:12.765 ListenConnect SL: connected phonesystem:0/VoiceBoxManagerService at [phonesystem]/VoiceBoxManagerService
    19:25:11.093 DBA [CM501003]: Connected: Database
    19:25:10.046 IVRConnected [CM501004]: Connected: IVR Service
    19:25:10.000 ListenConnect SL: connected phonesystem:5483/IVRServer at [phonesystem]/IVRServer
    19:25:09.890 CallMgr::findLocalIPs [CM501006]: Default Local IP address: [192.168.1.4]
    19:25:09.718 MediaServerConnected [CM112000] Media Server is connected
    19:25:09.718 ListenConnect SL: connected phonesystem:0/MediaServer at [phonesystem]/MediaServer
    19:25:09.656 CallCtrl::thread [CM501007]: *** Started Calls Controller thread ***
    19:25:09.656 CallMgr::Initialize [CM501002]: Version: 5.0.3790.0
    19:25:09.656 CallMgr::Initialize [CM501001]: Start 3CX PhoneSystem Call Manager
    19:25:09.375 LoadLicenceInfo [CM501009]: License Info: Loaded Succeeded
  2. css
    css
    Aug 15, 2007
    21
    I am sorry for wasting anyones time but I guess I just didn't have enough patience. Because now they are all slowly registering.
