Problems remain in VoIPBuster registration preccess
Discussion in '3CX Phone System - General' started by mbeain, Mar 28, 2007.
  1. mbeain
    Feb 6, 2007
    6
    I get this:
    Registration of sip:person@sip.voipbuster.com has failed; reason=Service Unavailable
    3CX says that Voipbuster service is anavailable, but if I register at Voipbuster with SJPhone, I have no problems.
    All is running in the same machine, so there's no issues about port blocking or firewalling.
    Thank you.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    This failure often happens if PBX can not resolve FQDN of provider, specified in settings. Check the spelling of FQDN. Try to ping it. If it is correct and pingable -- try to specify its IP instead of FQDN.
  3. mbeain
    Feb 6, 2007
    6
    ok, thank you, it works
    Configuring IP addresses instead of FQDN, 3CX got registered for VoipBuster. My ISP' s DNS server works well, but for some reason 3cx was not able to obtain that IP address and register succesfully.
    Now it works well.
  4. baukevda
    May 14, 2007
    Voipbuster is still a crime, can anybody post a screenprint with a working configuration ? Thanks in advance.
