Problems to use GSM codec
Discussion in '3CX Phone System - General' started by rfl2, Apr 4, 2010.
  1. rfl2
    Apr 4, 2010
    I'm doing tests with 3CX and I'm having problems to implement the codec GSM. When I set my client to use this codec, I get this error in the client: Server Internal Error. I'm using x-lite as a phone client.
    In the server, I get these messages:
    Code:
    10:08:45.718  Active calls counted toward license limit: []
    10:08:42.703  [CM503020]: Normal call termination. Reason: Server Failure
    10:08:42.703  [CM503016]: Call(12): Attempt to reach "101"<sip:101@lovato.us.to> failed. Reason: Not Implemented
    10:08:42.687  [CM503003]: Call(12): Call to sip:101@10.10.42.2 has failed; Cause: 488 Not Acceptable Here; warning: Media type not available; from IP:10.10.42.109:5061
    10:08:42.609  [CM503025]: Call(12): Calling Ext:Ext.101@[Dev:sip:101@10.10.42.109:5061]
    10:08:42.593  [CM503004]: Call(12): Route 1: Ext:Ext.101@[Dev:sip:101@10.10.42.109:5061]
    10:08:42.593  [CM503010]: Making route(s) to "101"<sip:101@lovato.us.to>
    10:08:42.593  [CM505001]: Ext.102: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite release 1104o stamp 56125] PBX contact: [sip:102@189.4.248.45:5060]
    10:08:42.578  [CM503001]: Call(12): Incoming call from Ext.102 to "101"<sip:101@lovato.us.to>
    10:08:13.718  Active calls counted toward license limit: []
    10:07:41.718  Active calls counted toward license limit: []
    10:07:09.718  Active calls counted toward license limit: []
    10:06:37.718  Active calls counted toward license limit: []
    10:06:05.718  Active calls counted toward license limit: []
    10:05:33.718  Active calls counted toward license limit: []
    Not implemented?? In the 3CX documentation, I read that was a standard codec.
    How can I use GSM codec in 3CX?
    Thanks,
    Roger
    11,105
    329
    Does it work using other Codecs?
  3. rfl2
    Apr 4, 2010
    Yes.. works fine just with ulaw and alaw.
    Thanks,
    Roger
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Roger,
    then you need to configure your device which answers Not acceptable here (IP:10.10.42.109:5061)
    to support GSM codec or configure your "GSM only" extension(102) as "PBX delivers audio=on"
    This information is available in documentation, articles and training videos published on wiki.3cx.com.
    If you need to play with specific details of SIP/RTP then you need to have advanced knowledge in this area.
