Problems /w outgoing calls - Linksys SPA942
Discussion in '3CX Phone System - General' started by marcus, Aug 12, 2007.
  1. marcus
    Aug 12, 2007
    I am new to 3CX but so far I have all up and running including Exchange 2007 UM. I am using Express Talk and added an SPA942.
    The configuration so far was quite easy and the phone successfully registers with 3CX and can place calls to internal extensions.
    But when I try to reach an external number (which I can without any problems using Express Talk), I get a busy tone and the connection ends.
    When I set a -cfwd all to an external number (e.g. my mobile) and call the extension, the call is correctly forwarded.
    Hopefully, someone here experienced the same and can help me out.
    Thanks,
    Marcus
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Marcus,
    Please refer to this guide http://www.3cx.com/sip-phones/linksys-SPA-921.html to config your SPA942. Since the config SPA XXX should be almost the same.
    Hope this help to solve your issue.
    5Q
