Problems with 2nd call on a ring group
Discussion in '3CX Phone System - General' started by phil83, Oct 4, 2016.
  1. phil83
    Oct 4, 2016
    Hello everybody,
    I manage a 3cx with 5 agents. I distribute two external numbers to two ring groups. Each ring group has 5 agents.
    So far this works well.
    But: If one agent accepts a call any other incoming is redirected to "busy" two seconds later without beeing redirected to the four free agents.
    Unfortunately I have no idea what I did wrong here. Any idea what I might consider?
    Thanks & Greetings
    11,111
    329
    Not knowing exactly how you have things set up, means there could be a number of issues. You might want to provide a few more details about how you have the ring groups configured, along with a post of the 3CX log showing the failed, second call.
