Daryle
- Joined
- May 16, 2018
- Messages
- 20
- Reaction score
- 1
I'm migrating from a previous SIP provider that is going out of business. My previous provider only required me to have a Linksys Phone Adapter box and an analog phone attached to it.
I've subscribed to Flowroute and have a DID and I have installed 3CX v 15.5.10244.4 on a INTEL NUC mini-PC in my home office in a DMZ between my Cable Internet provider's Router and my internal small office firewall/router. The public IP number provided by the Cable provider is dynamically allocated but reasonably persistent and stable (months at a time).
The INTEL NUC IP# is 192.168.0.240. I have successfully conducted the 3CX Firewall tests on this installation and installed the "3CXPhone for Windows" v.15.5.10795. on a laptop device inside my office network with IP# 192.168.2.185.
I've been able to receive incoming calls from the mobile phone. But I can't use the softphone to make outgoing calls. The call seems to attempt and then just drop. The 3CX has the following log entries (note that I've obfuscated my UID and phone numbers with some #### characters:
05/16/2018 2:30:10 PM - Call to T:Line:10000>>403929####@[Dev:sip:6062####@sip.flowroute.com:5060] from L:27.1[Extn:00] failed, cause: Cause: 484 Address Incomplete/INVITE from 216.115.69.144:5060
05/16/2018 2:30:10 PM - [CM503003]: Call(C:27): Call to <sip:403929####@sip.flowroute.com:5060> has failed; Cause: 484 Address Incomplete/INVITE from 216.115.69.144:5060
05/16/2018 2:28:00 PM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478/UDP fk=0; ignored
05/16/2018 2:25:06 PM - Call to T:Line:10000>>403929####@[Dev:sip:6062####@sip.flowroute.com:5060] from L:25.1[Extn:00] failed, cause: Cause: 484 Address Incomplete/INVITE from 216.115.69.144:5060
05/16/2018 2:25:06 PM - [CM503003]: Call(C:25): Call to <sip:403929####@sip.flowroute.com:5060> has failed; Cause: 484 Address Incomplete/INVITE from 216.115.69.144:5060
05/16/2018 1:38:33 PM - Call to T:Extn:00@[Dev:sip:[email protected]:3974;rinstance=0-969496303c214822940f109fe9dd6aae;ob] from L:19.1[Line:10000<<+1403929####] failed, cause: Cause: 404 Not Found/INVITE from 192.168.0.185:3974
05/16/2018 1:38:33 PM - [CM503003]: Call(C:19): Call to <sip:[email protected]:5060> has failed; Cause: 404 Not Found/INVITE from 192.168.0.185:3974
05/16/2018 1:34:52 PM - Call to T:Extn:00@[Dev:sip:[email protected]:3974;rinstance=0-969496303c214822940f109fe9dd6aae;ob] from L:17.1[Line:10000<<+14039290599] failed, cause: Cause: 404 Not Found/INVITE from 192.168.0.185:3974
As mentioned in one of the 3CX configuration documents, I have only 1 outbound rule:
Rule Name: Outbound Calls
Calls to numbers starting with prefix: +,0-9
Route 1: Flowroute
Strip Digits: 0
Any help would be very appreciated.
Route 1: Flowroute
Strip Digits: 0
