Problems with AudioCodes MP-114
Discussion in '3CX Phone System - General' started by tjabaut, Nov 6, 2007.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I have configured this device per the whitepaper; however I am not able to get outbound calling working. I keep getting the following:
    16:18:27.275 CallConf::Rejected [CM103005] Call(1) is rejected: Not Found
    16:18:27.275 StratInOut::eek:nCancel [CM104008] Call(1): Call from Ext.116 to 1518XXXXXXX terminated; cause: 404 Not Found; from IP:192.168.5.8
    16:18:26.494 CallConf::eek:nIncoming [CM103002] Call(1): Incoming call from 116 (Ext.116) to sip:91518XXXXXXX@192.168.5.2
    On the AudioCodes device I am getting the following in the Message Log:
    Log is Activated 6d:16h:18m:26s ( lgr_TrnkGrp)(35 ) !! [ERROR] #1:TrunkGroup::AllocateEndPoint- Can't find EndPoint for phone number 1518XXXXXXX [Time: 16:18:26]
    6d:16h:18m:26s ( lgr_psbrdif)(36 ) !! [ERROR] MotherBoard::GetEndPoint- Can't find EndPoint for Dest:1518XXXXXXX
    Source:116 SourceIp:10c68e0 [Time: 16:18:26]
    6d:16h:18m:26s task GWAP, Un nested AcLockStart [Time: 16:18:26]
    6d:16h:18m:26s task GWAP, Mismatch preemption mode [Time: 16:18:26]
    I am using a Grandstream GXP-2000, and internal calls work flawlessly as do external inbound calls.
    I am really struggling trying to get this working properly.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    As far as I understand your AudioCodes doesn't know how to dial number 1518XXXXXXX. Check its dial plan.
  3. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I realize that, that is what I am looking for info on. Has anybody on the board gotten one of these to work? and if so how did they do it.
  4. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    I just went over the configuration guide from the begining after resetting the MP114 to make sure we didn't skip any steps in the guide.It's working great. Just make sure you didn't skip any steps in the configuration guide. you must have missed some small but important setting.
    http://www.3cx.com/voip-gateways/audiocodes-mp.html
  5. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    Costas,
    I did go through the guide several times. what firmware ver are you using?
    Could you send the ini file that you used to get working. you should be able to save this file from within the audiocodes web interface.
    Also, I noticed on the Automatic Dialing you have changed from enabled to hotline. I attempted this, but calls would not ring to my phones. Instead 3CX would answer the call and immediately give the calling party a dial tone (much like two stage dialing). Upon hanging up 3CX would then make a call to the extension that was supposed to ring; however the line had already been dropped.
    Do you know how to perform a factory reset of the AudioCodes? The manual says to hold the reset button for 6 seconds, but it does not seem to work.
    I am very disappointed with this unit. It came highly recommeded for its sound quality, but audiocodes near non-existant support really makes the device useless.
  6. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    Costas,
    also on step 7.d you are specifying Set the “Default Gateway Address” to “10.172.0.253”.
    this is not one of your assumptions and in step 9 you are setting the default gateway address to 10.172.0.1 on the PC.
    Is this a typo?
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi tjabaut,
    Please find the config file as below for your reference. Our MP-114 works fine. Only found the FXO port 2 decode the caller id is not stable. That's mean not always can show the caller id.
    ;** Ini File **
    ;Board: MP-114 FXO
    ;Serial Number: 942649
    ;Slot Number: 1
    ;Software Version: 5.00A.024
    ;DSP Software Version: 204IM => 209.13
    ;Board IP Address: 10.1.1.208
    ;Board Subnet Mask: 255.255.255.0
    ;Board Default Gateway: 10.1.1.253
    ;Ram size: 32M Flash size: 8M
    ;Num DSPs: 1 Num DSP channels: 4
    ;Profile: NONE
    [SYSTEM Params]
    DNSPriServerIP = 203.80.96.10
    DNSSecServerIP = 203.80.96.9
    SyslogServerIP = 10.1.1.218
    EnableSyslog = 1
    VXMLFIleName = ''
    ActivityListToLog = 'pvc', 'afl', 'dr', 'fb', 'swu', 'ard', 'naa', 'spc'
    SyslogServerPort = 514
    [BSP Params]
    PCMLawSelect = 3
    EnableMultipleIPs = 0
    NETWORKSERVICECLASSDIFFSERV = 48
    PREMIUMSERVICECLASSMEDIADIFFSERV = 46
    PREMIUMSERVICECLASSCONTROLDIFFSERV = 40
    GOLDSERVICECLASSDIFFSERV = 26
    BRONZESERVICECLASSDIFFSERV = 10
    RoutingTableHopsCountColumn = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
    [ATM Params]
    [Analog Params]
    MinFlashHookTime = 100
    FXSLoopCharacteristicsFilename = 'MP11x-02-1-FXS_16KHZ.dat'
    [ControlProtocols Params]
    [MGCP Params]
    [MEGACO Params]
    DIGITMAPPING = ''
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [PSTN Params]
    [SS7 Params]
    [Voice Engine Params]
    DJBufMinDelay = 70
    RFC2833PayloadType = 101
    CallProgressTonesFilename = 'usa_tones_12.dat'
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    MAXDIGITS = 49
    TIMEBETWEENDIGITS = 4
    TIMEFORREORDERTONE = 255
    TIMEFORDIALTONE = 16
    LOCALSIPPORT = 5060
    PLAYRBTONE2IP = 0
    ISSPECIALDIGITS = 0
    DISCONNECTONBUSYTONE = 1
    SIPT1RTX = 500
    SIPT2RTX = 4000
    ISPROXYUSED = 1
    ISREGISTERNEEDED = 1
    SIPDESTINATIONPORT = 5060
    PLAYRBTONE2TEL = 2
    ISWAITFORDIALTONE = 0
    ISTWOSTAGEDIAL = 0
    DETFAXONANSWERTONE = 0
    FXOBETWEENRINGTIME = 8
    ENABLECURRENTDISCONNECT = 1
    ENABLEREVERSALPOLARITY = 1
    CHANNELSELECTMODE = 2
    GWDEBUGLEVEL = 5
    ENABLERPIHEADER = 0
    ENABLEEARLYMEDIA = 1
    ISUSERPHONE = 1
    SIPSESSIONEXPIRES = 0
    DEFAULTNUMBER = '1000'
    PROXYNAME = '10.1.1.228'
    SIPGATEWAYNAME = 'istoneage.com'
    STATICNATIP = 0.0.0.0
    ENABLEVOICEDETECTION = 0
    RXDTMFOPTION = 3
    PRACKMODE = 0
    SIPMAXRTX = 7
    ASSERTEDIDMODE = 0
    ISUSERPHONEINFROM = 0
    ADDTON2RPI = 1
    USESOURCENUMBERASDISPLAYNAME = 0
    MINSE = 90
    IPALERTTIMEOUT = 180
    ISFAXUSED = 1
    SIPTRANSPORTTYPE = 0
    TCPLOCALSIPPORT = 5060
    SENDMETERING2IP = 0
    RINGSBEFORECALLERID = 1
    HOTLINETONEDURATION = 16
    SIP183BEHAVIOUR = 0
    TLSLOCALSIPPORT = 5061
    ENABLESIPS = 0
    USERAGENTDISPLAYINFO = ''
    SESSIONEXPIRESMETHOD = 0
    USEDISPLAYNAMEASSOURCENUMBER = 0
    USESIPTGRP = 0
    SIPSUBJECT = ''
    GUARDTIMEBETWEENCALLS = 1
    DISCONNECTONDIALTONE = 0
    CODERNAME = g711Ulaw64k,20,0,0,0
    CODERNAME = g711Alaw64k,20,0,8,0
    PREFIX = 10,10.1.10.10,*,0,255
    PSTNPREFIX = *,1,*,*,0
    TARGETOFCHANNEL0 = 20001,1
    TARGETOFCHANNEL1 = 20002,1
    TARGETOFCHANNEL2 = 20003,1
    TARGETOFCHANNEL3 = 20004,1
    TRUNKGROUP = 1-1,20001,1
    TRUNKGROUP = 2-2,20002,1
    TRUNKGROUP = 3-3,20003,1
    TRUNKGROUP = 4-4,20004,1
    TRUNKGROUP_1 = 5-5,105,0
    TRUNKGROUP_1 = 6-6,106,0
    TRUNKGROUP_1 = 7-7,107,0
    TRUNKGROUP_1 = 8-8,108,0
    PROXYIP = 10.1.1.228
    AUTHENTICATION_0 = 20001,20001
    AUTHENTICATION_1 = 20002,20002
    AUTHENTICATION_2 = 20003,20003
    AUTHENTICATION_3 = 20004,20004
    TXDTMFOPTION = 4
    ;TelProfile: ProfileName, Preference, CodersGroupID, IsFaxUsed, DJBufMinDelay, JBufOptFactor, IPDiffServ, SigIPDiffServ, DtmfVolume, InputGain, VoiceVolume, EnableReversePolarity, EnableCurrentDisconnect, EnableDigitDelivery, ECE, MWIAnalog, MWIDisplay, FlashHookPeriod, EnableEarlyMedia, ProgressIndicator2IP
    TELPROFILE_1 = Default Tel Profile,1,0,1,70,10,46,40,-11,0,0,0,0,0,1,0,0,400,1,0
    [VXML Params]
    [IPsec Params]
    [Audio Staging Params]
    DisableSNMP = 0
    SNMPTrapManagerHostName = ''
    ; *** TABLE DspTemplates ***
    ; This table contains hidden elements and will not be exposed.
    ; This table exists on board and will be saved during restarts
  8. vwadher
    Mar 11, 2007
    17
    I HAVE A SOLUTION!!
    This issue is regarding MP-114 FXO AUDIO CODES cause: BYE; reason: Q.850 ;cause=3
    Hello Friend,
    I have the SAME ISSUE. I fixed it!
    Goto Advanced Config --> Configuration File --> DOWNLOAD THE INI FILE
    IN the file.... change the TARGET OF CHANNEL to xxx,1 for all.
    See below..
    TARGETOFCHANNEL0 = xxxxx,1
    TARGETOFCHANNEL1 = xxxxx,1
    Then SAVE the file... and UPLOAD the FILE to your DEVICE from the SAME area.
    When I got my INI file... I saw it was set to 2 !!! I don't know why... but thats how it was.
    I'm certain this is your issue!
    Please post back so I know I helped someone.
  9. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    vwadher,
    Thanks for the advice; however mine is already set to 1.
    I have reset the device, installed the latest firmware and still not outbound dialing.
    I have started working on a different config altogether for 3CX with this device. Nick and Costas, you will be interested to know that I have been able to get this device working on inbound calls by simply setting it up as a VOIP trunk. It is not using the proxy (but it can) nor is it registering.
    The Audiocodes unit merely receives the PSTN call, converts to voip and transfers it based on the routing rule and the autodial rules to the 3CX box.
    Outbound calls do ring and are passed to the Audiocodes box, but they do not get outside of this box.
    I will continue to troubleshoot, and will post a writeup for your review when finished.
    If anyone has anymore experience with the Audiocodes MP units as to why it will not pick up a port and dial out I am all ears.
    Thanks again,
    Tim
  10. LLangston
    Aug 27, 2007
    57
    After putting your configuration in the gateway did you got to Mainenance and go down to Save Configuration and press the burn button. I found that just hitting the submit button did not do it, I had to burn the config to the gateway before outbound calls would work. Once I did that it worked great and the audio quality is great. It will still need some fine tuning and I am still working on that. I am finding that the Caller ID feature is not stable but not sure if that is in the gateway or in the phones at this time. But on a scale of 1 - 10 I would give the MP-114 an 8+.
  11. vwadher
    Mar 11, 2007
    17
    hello,
    I got the INCOMING calls to work.... but now I'm having the same issues as the other person here...
    OUTGOING calls are not working. They are getting OUT from 3CX.... but the MP114 gateway does not know what to do with it...
    GATEWAY LOGS -->
    Call::GetEndPoint- Can't find endpoint for phone number 14807756464
    I did enable HOTLINE and also BURN to the flash etc.
    Any help would be appreciated. Thanks,
  12. vwadher
    Mar 11, 2007
    17
    Hello Friend,
    I GOT MINE WORKING FOR OUTGOING CALLS !!
    PROTOCOL MANAGEMENT -->
    ROUTING TABLES -->
    IP to Hunt Group Routing Table --->
    Hunt Group ID = 0
    Profile ID = 1
    Let me know if you get it working too!
    I will be more than happy to help more if you need.
  13. Glavan Alexandru
    Jul 17, 2012
    Hello everybody...
    I have an AudiCodes MP-114 FXS, I can make calls... everything works fine till now, except that, if ext 101 calls ext 102, and it cancels the call, ext 102 is still ringing.
    This is the BOARD.INI
    ;** Ini File **
    ;Board: MP-114 FXS
    ;Serial Number: 460703
    ;Slot Number: 1
    ;Software Version: 5.60A.009.005
    ;DSP Software Version: 204IM => 560.10
    ;Board IP Address: 192.168.1.98
    ;Board Default Gateway: 192.168.1.3
    ;Profile: NONE
    [SYSTEM Params]
    VXMLFIleName = ''
    [BSP Params]
    PCMLawSelect = 3
    EnableLANWatchdog = 0
    StorageServerNetworkAddress = 255.255.255.255
    [ATM Params]
    [Analog Params]
    [MGCP Params]
    [MEGACO Params]
    DIGITMAPPING = ''
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [PSTN Params]
    [SS7 Params]
    FarEndDisconnectSilenceMethod = 2
    FarEndDisconnectSilencePeriod = 120
    IdlePCMPattern = 85
    BrokenConnectionEventTimeout = 100
    RFC2833PayloadType = 96
    DTMFDetectorSensitivity = 1
    TTYTRANSPORTTYPE = 1
    [WEB Params]
    [SIP Params]
    MAXDIGITS = 49
    ISPROXYUSED = 1
    AUTHENTICATIONMODE = 0
    PLAYRBTONE2TEL = 2
    ENABLEBUSYOUT = 1
    CHANNELSELECTMODE = 0
    REGISTRARIP = '192.168.1.3'
    SIPGATEWAYNAME = '192.168.1.3'
    USERNAME = 'admin'
    PASSWORD = 'admin'
    ENABLESILENCEDISCONNECT = 1
    PROGRESSINDICATOR2IP = -1
    HOOKFLASHOPTION = 4
    ALWAYSSENDTOPROXY = 1
    PRACKMODE = 0
    XFERPREFIX = '*'
    CDRSYSLOGSERVERIP = 0.0.0.0
    PSTNALERTTIMEOUT = 180
    IPALERTTIMEOUT = 30
    GWREGISTRATIONNAME = '192.168.1.3'
    REGISTRARNAME = '192.168.1.3'
    ENABLESIPS = 0
    FXSOOSBEHAVIOR = 4
    DNSQUERYTYPE = 1
    PROXYDNSQUERYTYPE = 1
    REDUNDANTROUTINGMODE = 0
    EmergencyNumbers = '', '', '', ''
    REGISTRARTRANSPORTTYPE = 0
    [SCTP Params]
    [VXML Params]
    [IPsec Params]
    ChassisPhysicalAlias = ''
    ChassisPhysicalAssetID = ''
    ifAlias_0 = ''
    ifAlias_1 = ''
    ifAlias_2 = ''
    ifAlias_3 = ''
    ifAlias_4 = ''
    ifAlias_5 = ''
    ifAlias_6 = ''
    ifAlias_7 = ''
    ifAlias_8 = ''
    ifAlias_9 = ''
    VideoEnableTestPattern = 1
    VideoRateControlType = 0
    ; *** TABLE CoderName ***
    [ CoderName ]
    FORMAT CoderName_Index = CoderName_Type, CoderName_PacketInterval, CoderName_rate, CoderName_PayloadType, CoderName_Sce;
    CoderName 0 = g711Alaw64k, 20, 0, 255, 0;
    CoderName 1 = g711Ulaw64k, 20, 0, 255, 0;
    [ \CoderName ]
    ; *** TABLE TrunkGroup ***
    [ TrunkGroup ]
    FORMAT TrunkGroup_Index = TrunkGroup_TrunkGroupNum, TrunkGroup_FirstTrunkId, TrunkGroup_FirstBChannel, TrunkGroup_LastBChannel, TrunkGroup_FirstPhoneNumber, TrunkGroup_ProfileId, TrunkGroup_LastTrunkId, TrunkGroup_Module;
    TrunkGroup 0 = 0, 255, 1, 1, 100, 1, 255, 255;
    TrunkGroup 1 = 0, 255, 2, 2, 101, 1, 255, 255;
    TrunkGroup 2 = 0, 255, 3, 3, 102, 1, 255, 255;
    TrunkGroup 3 = 0, 255, 4, 4, 103, 1, 255, 255;
    [ \TrunkGroup ]
    ; *** TABLE ProxyIp ***
    [ ProxyIp ]
    FORMAT ProxyIp_Index = ProxyIp_IpAddress, ProxyIp_TransportType, ProxyIp_ProxySetId;
    ProxyIp 0 = 192.168.1.3, 0, 0;
    [ \ProxyIp ]
    ; *** TABLE TxDtmfOption ***
    [ TxDtmfOption ]
    FORMAT TxDtmfOption_Index = TxDtmfOption_Type;
    TxDtmfOption 0 = 4;
    [ \TxDtmfOption ]
    ; *** TABLE TrunkGroupSettings ***
    [ TrunkGroupSettings ]
    FORMAT TrunkGroupSettings_Index = TrunkGroupSettings_TrunkGroupId, TrunkGroupSettings_ChannelSelectMode, TrunkGroupSettings_RegistrationMode, TrunkGroupSettings_GatewayName, TrunkGroupSettings_ContactUser, TrunkGroupSettings_ServingIPGroup;
    TrunkGroupSettings 0 = 1, 0, 0, , , -1;
    [ \TrunkGroupSettings ]
    ; *** TABLE TelProfile ***
    [ TelProfile ]
    FORMAT TelProfile_Index = TelProfile_ProfileName, TelProfile_TelPreference, TelProfile_CodersGroupID, TelProfile_IsFaxUsed, TelProfile_JitterBufMinDelay, TelProfile_JitterBufOptFactor, TelProfile_IPDiffServ, TelProfile_SigIPDiffServ, TelProfile_DtmfVolume, TelProfile_InputGain, TelProfile_VoiceVolume, TelProfile_EnableReversePolarity, TelProfile_EnableCurrentDisconnect, TelProfile_EnableDigitDelivery, TelProfile_EnableEC, TelProfile_MWIAnalog, TelProfile_MWIDisplay, TelProfile_FlashHookPeriod, TelProfile_EnableEarlyMedia, TelProfile_ProgressIndicator2IP, TelProfile_TimeForReorderTone, TelProfile_EnableDIDWink, TelProfile_IsTwoStageDial, TelProfile_DisconnectOnBusyTone;
    TelProfile 1 = "Default Tel Profile", 1, 0, 0, 10, 10, 46, 40, -11, 0, 0, 1, 0, 0, 1, 0, 0, 400, 0, -1, 255, 0, 1, 1;
    [ \TelProfile ]
    ; *** TABLE CallerDisplayInfo ***
    [ CallerDisplayInfo ]
    FORMAT CallerDisplayInfo_Index = CallerDisplayInfo_DisplayString, CallerDisplayInfo_IsCidRestricted;
    CallerDisplayInfo 0 = 100, 0;
    CallerDisplayInfo 1 = 101, 0;
    CallerDisplayInfo 2 = 102, 0;
    CallerDisplayInfo 3 = 103, 0;
    [ \CallerDisplayInfo ]
    ; *** TABLE Authentication ***
    [ Authentication ]
    FORMAT Authentication_Index = Authentication_UserId, Authentication_UserPassword;
    Authentication 0 = 100, 100;
    Authentication 1 = 101, 101;
    Authentication 2 = 102, 102;
    Authentication 3 = 103, 103;
    [ \Authentication ]
    ; *** TABLE ProxySet ***
    [ ProxySet ]
    FORMAT ProxySet_Index = ProxySet_EnableProxyKeepAlive, ProxySet_ProxyKeepAliveTime, ProxySet_ProxyLoadBalancingMethod, ProxySet_IsProxyHotSwap;
    ProxySet 0 = 1, 60, 0, 1;
    [ \ProxySet ]
  14. Glavan Alexandru
    Jul 17, 2012
    ... and this is the syslog from AudioCodes:
    17d:15h:30m:47s ( sip_stack)(432 ) AcSIPParser: Problem in SIP Message Headers
    17d:15h:30m:47s ( sip_stack)(433 ) !! [ERROR] AcSIPParser: Parse Error. Unexpected symbol ';'. Expected '='
    17d:15h:30m:47s ( sip_stack)(434 ) !! [ERROR] Message type: CANCEL
    17d:15h:30m:47s ( sip_stack)(435 ) !! [ERROR] Source header:
    17d:15h:30m:47s ( sip_stack)(436 ) !! [ERROR] Line: 9. Column: 19
    17d:15h:30m:47s CANCEL sip:101@192.168.1.98:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.3:5060;branch=z9hG4bK-d8754z-ea2daf7c3903c66e-1---d8754z-;rport
    Max-Forwards: 70
    To: <sip:101@192.168.1.3>
    From: "10003"<sip:103@192.168.1.3:5060>;tag=32188453
    Call-ID: MTViMDBkZWZlMzllOGZhZGQxNzBmMzUyM2I3MWNhOGE.
    CSeq: 1 CANCEL
    User-Agent: 3CXPhoneSystem 11.0.25940.0
    Reason: Q.850;text;cause=16
    Content-Length: 0
