Problems with Avaya CS1000 adding phone-context=cdp.udp
Discussion in '3CX Phone System - General' started by BAYSHORE, Feb 8, 2013.
  1. BAYSHORE
    Jul 16, 2010
    5
    I have a SIP trunk between AVAYA CS1000 and 3cx.....when a call comes in from the CS1000 it is adding phone-context=cdp.udp to the TO: Field in the INVITE.....Does anyone know to strip this out of the TO: Field
    Here is the LOG
    I replaced the Hostname and the IP addresses to protect the innocent....
    16:19:15.585 [CM102001]: Authentication failed for SipReq: INVITE 1384;phone-context=cdp.udp@xxx.xxx.xxx.xxx:5060 tid=AC1F287B26254FF30787782-AP cseq=INVITE contact=46539;phone-context=cdp.udp@hillromtest.org:5060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    16:19:15.585 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:1384;phone-context=cdp.udp@xxx.xxx.xxx.xxx:5060;transport=udp;user=phone;x-nt-redirect=redirect-server SIP/2.0
    Via: SIP/2.0/UDP 172.31.xxx.xxx;rport=5060;branch=z9hG4bKAC1F287B26254FF30787782-AP;ft=172.31.xxx.xxx~13c4
    Via: SIP/2.0/UDP 172.31.xxx.xxx:15070;branch=z9hG4bKAC1F287B26254FF30787782
    Via: SIP/2.0/UDP 172.31.xxx.xxx:15070;branch=z9hG4bKAC1F287B26254FF31787780
    Via: SIP/2.0/UDP 172.31.xxx.xxx:15070;branch=z9hG4bKAC1F287B26254FF31787779
    Via: SIP/2.0/UDP 172.31.xxx.xxx;rport;branch=z9hG4bK-1567241-39ae4f73-11632959-AP;ft=172.31.xxx.xxx~13c4
    Via: SIP/2.0/UDP 172.31.xxx.xxx:5060;branch=z9hG4bK-1567241-39ae4f73-11632959
    Max-Forwards: 66
    Route: <sip:xxx.xxx.xxx.xxx;lr;phase=terminating>
    Record-Route: <sip:1520d06c@172.31.xxx.xxx;transport=udp;lr>
    Record-Route: <sip:172.31.xxx.xxx:15060;lr;sap=-1867748178*1*016asm-callprocessing.sar2066226860~1360102755617~161401105~1>
    Contact: <sip:46539;phone-context=cdp.udp@hillromtest.org:5060;maddr=172.31.xxx.xxx;transport=udp;user=phone>
    To: <sip:1384;phone-context=cdp.udp@hillromtest.org;user=phone>
    From: "RUDY'S TEST PHONE"<sip:46539;phone-context=cdp.udp@hillromtest.org;user=phone>;tag=84010a8-5281fac-13c4-40030-1567241-3ebc44a-1567241
    Call-ID: afd2d560-5281fac-13c4-40030-1567241-5528cce4-1567241
    CSeq: 2 INVITE
    Min-SE: 0
    Alert-Info: <cid:internal@hillromtest.org>
    Allow: INVITE, ACK, BYE, REGISTER, REFER, NOTIFY, CANCEL, PRACK, OPTIONS, INFO, SUBSCRIBE, UPDATE
    Proxy-Authorization: Digest username="ACH_1000E",realm="3CXPhoneSystem",nonce="414d535c0722166347:339e340d3980e02080dbad9f0719ebb7",uri="sip:1384;phone-context=cdp.udp@hillromtest.org:5060;maddr=172.31.xxx.xxx;transport=udp;user=phone;x-nt-redirect=redirect-server",response="d9ddce97f9c2f8d5623e338a27583544",algorithm=MD5
    Supported: 100rel, x-nortel-sipvc, replaces, timer
    User-Agent: Nortel CS1000 SIP GW release_6.0 version_ssLinux-6.00.18 AVAYA-SM-6.1.5.0.615006
    Privacy: none
    P-Asserted-Identity: "RUDY'S TEST PHONE" <sip:46539;phone-context=cdp.udp@hillromtest.org;user=phone>
    Content-Length: 0
    x-nt-corr-id: 001f9f5a1013100502@00247f969c52-54cdc122
    History-Info: <sip:1384;phone-context=cdp.udp@hillromtest.org;user=phone>;index=1,<sip:1384;phone-context=cdp.udp@hillromtest.org;user=phone>;index=1.1
    P-Location: SM;origlocname="NRS";termlocname="NNC"
    ________________________________________
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CX PhoneSystem is very tolerant to interpretations of RFC 3261 (definition of SIP protocol), but these headers are going far beyond the bounds of possible tolerance...
    Sorry, but it will not work even if you remove that "parameter" :(
  3. 71jav2t
    Mar 12, 2013
    On the 3CX server, try putting this into the SIP ID of the extension. It is located in the tab labeled "Other"
    I think this will work if you are running version 11.
    The cdp.udp context can also be removed in the CS1000, but I would not recommend unless you know what you are doing.
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    ... and what will it resolve?
  5. 71jav2t
    Mar 12, 2013
    It should allow for extensions on the Avaya CS1000 to make calls to extensions on the 3CX. Specifically in the example above, extension 46539 on the CS1000 should be able to call extension 1384 on the 3CX.
