15:31:23.325 MediaServerReporting::RTPReceiver [MS105000] C:355.1: No RTP packets were received:remoteAddr=192.168.42.30:42004,extAddr=0.0.0.0:0,localAddr=192.168.42.3:7162
15:31:23.262 Call::Terminate [CM503008]: Call(355): Call is terminated
15:31:23.246 Call::RouteFailed [CM503015]: Call(355): Attempt to reach [sip:
[email protected]:5060] failed. Reason: Busy
15:31:23.246 CallLeg:
nFailure [CM503003]: Call(355): Call to sip:
[email protected]:5060 has failed; Cause: 486 Busy Here; from IP:212.23.7.228:5060
15:31:22.356 Line:
rintEndpointInfo [CM505003]: Provider:[Zen] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Zen Internet Telephony Service] Transport: [sip:192.168.42.3:5060]
15:31:22.356 CallCtrl:
nAnsweredCall [CM503002]: Call(355): Alerting sip:
15:31:13.184 Call::Terminate [CM503008]: Call(357): Call is terminated
15:31:13.184 Call::RouteFailed [CM503018]: Normal call termination. Reason: Away status is OFF
15:31:13.153 CallCtrl:
nSelectRouteReq [CM503010]: Making route(s) to [sip:*
15:31:13.153 Extension:
rintEndpointInfo [CM505001]: Ext.20: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone 6.0.727.0] Transport: [sip:192.168.42.3:5060]
nIncomingCall [CM503001]: Call(357): Incoming call from Ext.20 to [sip:*
15:31:09.309 Call::Terminate [CM503008]: Call(356): Call is terminated
15:31:09.309 Call::RouteFailed [CM503018]: Normal call termination. Reason: Away status is ON
15:31:09.293 CallCtrl:
15:31:09.278 Extension:
15:31:09.278 CallCtrl:
nIncomingCall [CM503001]: Call(356): Incoming call from Ext.20 to [sip:*
15:30:15.294 MediaServerReporting::STUN [MS101003] C:355.2: Possible firewall problem. Address mapping failed on STUN server 192.168.42.3:3478 for local address ":9000"
15:30:09.153 CallCtrl:
nSelectRouteReq [CM503004]: Call(355): Calling: VoIPline:141020783548@(Ln.10004@Zen)@[Dev:sip:
15:30:09.137 CallCtrl:
15:30:09.137 Extension:
nIncomingCall [CM503001]: Call(355): Incoming call from Ext.20 to [sip:
