Problems with calls being repeated
Discussion in '3CX Phone System - General' started by ejvind1212, Aug 11, 2008.
  1. ejvind1212
    Jul 7, 2008
    8
    We are a company testing 3cx. Our trial setup is a Linksys-3102 connected to a PSTN, and this works OK for both inbound and outbound calls. However, inbound calls need to be answered very quickly (approx. 5 sec) or 3cx will terminate the call, and generate a new call. In the 3cx server log it shows "..call terminated" and then "Call(2)..." and so on until the caller hangs up. It does not transfer to voice mail even though it should after 15 sec.
    It happens regardsless of whether the receiver is a hardware phone or the built-in 3cx softphone. However, if no phones with the user is registered it goes to 3cx Voice Mail, and the call is being pickup up correctly without generating a new call.
    The only happens for calls coming from Linksys-3102 - all internal calls are handled OK.
    If anyone has a suggestion for this, I would appreciate it very much.
    Thanks.
    BR / Ejvind
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Please confirm that the Linksys configuration was set up as specified in http ://www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
    What firmware does the Linksys have? Ensure you are updated to the latest Linksys firmware (5.1.7)
    regards
  3. ejvind1212
    Jul 7, 2008
    8
    Thanks for your reply.
    Yes, the Linksys 3102 has been setup according to the guide from 3Cx. However, we have allowed for caller id to be sent on inbound calls. I have also tried to disable this feature, but it does not change anything.
    We have now upgraded the firmware from version 3.3.6 to 5.1.5a as suggested, but it did not solve the problem. Version 5.1.7 is not available from Linksys web site.
    On the inbound call it displays this in the 3CX log file:
    Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.5(GWa)] Transport: [sip:192.168.1.14:5060]
    I do not know why - I am quite sure the the ID and pwd is correct.
    If we pick up the call within approx. 5 sec. everythings works OK.
    Thanks.
    Ejvind
  4. ejvind1212
    Jul 7, 2008
    8
    To be absolutely sure, we have done a factory reset on the Linksys 3102 and set it up again 100% according to the guide form 3Cx. It does not solve the problem.
    Ejvind
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    5.1.7 on linksys site and I have it
    reset your device to factory reset and reconfig it again
    change Ring Strategy to ring all
    change PSTN Answer Delay: to 4
  6. ejvind1212
    Jul 7, 2008
    8
    We finally solved it. The default value for "PSTN Ring Timeout" is 5 and by changing it to 15, everything works OK. Please note that it is also 5 in the 3cx guide for Linksys 3102 setup.
    We also found and installed firmware 5.1.7 on Linksys web site. It seems Linksys replicate their web site to regional sites which is not always updated with the latest information.
    Thanks for your assistance.
    Ejvind
  7. alexmallia
    3CX Support
    Aug 4, 2008
    130
    Thank you for the information provided. We will be taking note of this.
    regards
