Problems with calls landline to sip
Discussion in '3CX Phone System - General' started by miraportuga, Aug 11, 2007.
  1. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    First of all, hi, its my first post ever here.
    I've recently entered in the VoIp world and ive seen this amazing software.
    If i try to call outside i have no problems at all, i have 3 voip lines set and i can call with any of them.Now, if somene try's to call me to my VoIp number (can be called from a normal telephone) nothing happens, sometimes rings, sometimes not... this happens without me changing anything on the configuration... Im using a computer with 2003 server to run 3cx Phone system. Hope u can help me out here
    I've not included servers logs coz... simply nothing appears there.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi miraportuga,
    Are you using default setting? If yes. Please enable the log level to "Verbose (only used for debugging purposes)". Restart all 3cx services or restart 3cx box.
    You can get the details log at C:\Program Files\3CX PhoneSystem\Data\Logs\3CXPhoneSystem.trace.log
    Hope this help.
    Regards,
    5QG4
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    19:17:34.390|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:17:54.718|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    19:17:55.859|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:17:55.859|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:17:55.859|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 8)
    19:17:55.859|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](8)
    19:17:55.921|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:17:55.921|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:17:55.921|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:04.609|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:04.609|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:18:04.609|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 7)
    19:18:04.609|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](7)
    19:18:04.671|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:18:04.671|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:04.671|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:26.171|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:26.171|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:18:26.171|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 8)
    19:18:26.171|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](8)
    19:18:26.203|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:18:26.203|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:26.203|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:34.609|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:34.609|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:18:34.609|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 7)
    19:18:34.609|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](7)
    19:18:34.718|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:18:34.718|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:34.718|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:54.718|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    19:18:56.484|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:56.484|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:18:56.484|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 8)
    19:18:56.484|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](8)
    19:18:56.578|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:18:56.578|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:18:56.578|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:04.921|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:04.921|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:19:04.921|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 7)
    19:19:04.921|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](7)
    19:19:05.000|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:19:05.000|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:05.000|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:25.234|.\CAHandler.cpp(252)|Trace5||CAHandler::setStatus:[CM102005] CA request setStatus(dn=100, status=0)
    19:19:25.234|.\CAHandler.cpp(252)|Trace5||CAHandler::setStatus:[CM102005] CA request setStatus(dn=101, status=0)
    19:19:25.234|.\CAHandler.cpp(252)|Trace5||CAHandler::setStatus:[CM102005] CA request setStatus(dn=102, status=0)
    19:19:25.234|.\CAHandler.cpp(252)|Trace5||CAHandler::setStatus:[CM102005] CA request setStatus(dn=201, status=0)
    19:19:25.234|.\CAHandler.cpp(252)|Trace5||CAHandler::setStatus:[CM102005] CA request setStatus(dn=500, status=0)
    19:19:26.546|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:26.546|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:19:26.546|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 8)
    19:19:26.546|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](8)
    19:19:26.625|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:19:26.625|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:26.625|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 194.120.0.198:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:34.953|KeepAliveManager.cxx(67)|Debug8|Resip|>>:Refreshing keepalive for [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    19:19:34.953|KeepAliveManager.cxx(68)|Debug8|Resip|>>:Keepalive interval 30 seconds
    19:19:34.953|KeepAliveManager.cxx(69)|Debug8|Resip|>>:Keepalive id 7)
    19:19:34.953|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ](7)
    19:19:35.031|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 82.154.55.180:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by= sent-port=0
    19:19:35.031|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.13.86.168:5070 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 82.154.55.180:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    Hope that can help you guys helping me out lolz
    Thats what happens when i try to call from a landline to VoIp line
  4. Anonymous
    Anonymous Guest
    Something wrong with your IP config it talks about ip 0.0.0.0
    That cannot be correct.
    Is your VSP provider registered in 3CX?
    When calling your VoIP number it goest from:
    Landline ---> VSP ---> 3CX---> your IP phone.
    So you do not have to configure any ATA to talk to your VSP, only configure 3cx to talk to your VSP.
    Can you also post a serverlog (without Verbose?) To much info in this one for me, I get lost in it :).
  5. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Thats the thing if i choose server to log without nothing happens. its like the connection aint passing through or something. :|
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well, on an attempt to make things work i changed voip server to another computer, so that he could act behing NAT/firewall and not on the same machine, and so far.. so good, i can call every extension, i can call outside without any problem and ppl can call to my voip number.
    Thk u all for the help anyways :p
