Problems with CONCENATE operator in VAD
Discussion in 'CRM / Helpdesk / App Integration' started by jorlovs, Oct 10, 2012.
  1. jorlovs
    Oct 10, 2012
    I have situation where I need to create VAD project for telephone number lookup in the 3CX callhistory table. Problem starts in the moment when we call to customer with the call format 0XXXXXX, but when customer calls us he calls with the format XXXXXX.
    So to mach caller we need to caller XXXXXX number add 0 to make in SQL query.
    So I'm tryning CONCENATE operator in expression:
    CONCATENATE('0',RIGHT(session.ani,6)), but when created this it goes out with the error:
    ERROR [42883] ERROR: operator does not exist: character varying = integer; Error while executing the query
    In other case, if
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    How are you configuring your SQL query into your Database Access component?
    If the database field is a varchar, when you compare you need to add quotes. For example:
    SELECT * FROM table WHERE field_name = '{0}'
    And then configure your first parameter with the expression you mentioned:
    This is because the expression result will be put into the SQL query without quotes, so you need to add quotes to your SQL query to make the field a varchar.
