Problems with d-link dfl-200
Discussion in '3CX Phone System - General' started by AlGreen, Nov 12, 2008.
  1. AlGreen
    Nov 11, 2008
    i get theese warnings by the firewall checker:
    Code:
        3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
        <17:14:14>: Phase 1, checking servers connection, please wait...
        <17:14:14>: Stun Checker service is reachable. Phase 1 check passed.
        <17:14:14>: Phase 2a,  Check Port Forwarding to UDP SIP port, please wait...
        <17:14:15>: UDP SIP Port is set to 5061. Response received WITH TRANSLATION 3252::5061. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://<whatever>.
        <17:14:15>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
        <17:14:15>: TCP SIP Port is set to 5071. Response received WITH TRANSLATION 1558::5071. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://<whatever>.
        <17:14:15>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
        <17:14:15>: TCP TUNNEL Port is set to 5091. Response received WITH TRANSLATION 4950::5091. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://<whatever>.
        <17:14:15>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
        <17:14:27>: UDP RTP Port 9000. Response received WITH TRANSLATION 8065::9000. Phase 4-01 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9001. Response received WITH TRANSLATION 2898::9001. Phase 4-02 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9002. Response received WITH TRANSLATION 5312::9002. Phase 4-03 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9003. Response received WITH TRANSLATION 8995::9003. Phase 4-04 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9004. Response received WITH TRANSLATION 6556::9004. Phase 4-05 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9005. Response received WITH TRANSLATION 9177::9005. Phase 4-06 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9006. Response received WITH TRANSLATION 5556::9006. Phase 4-07 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9007. Response received WITH TRANSLATION 3723::9007. Phase 4-08 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9008. Response received WITH TRANSLATION 3440::9008. Phase 4-09 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        <17:14:27>: UDP RTP Port 9009. Response received WITH TRANSLATION 2548::9009. Phase 4-10 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://<whatever>.
        Application exit code is 13
    I tried the configuration provided here:
    http://portforward.com/english/routers/port_forwarding/Dlink/DFL-200/3CX.htm
    but nothing changes, same warnings. Does someone know the right configuration, or can explain me something about the warnings?
    Server logs:
    Code:
    09:35:15.437|.\CallCtrl.cpp(135)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(1): Incoming call from Ext.100 to <sip:0403@192.168.75.101:5060><br>
    09:35:15.484|.\Extension.cpp(903)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [3CX Phone 7.0.3387.0] Transport: [sip:192.168.75.101:5060]<br>
    09:35:15.484|.\CallLeg.cpp(728)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:1.1<br>
    09:35:15.515|.\SLServer.cpp(674)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:1.1:Offer received. RTP connection: 192.168.75.41:42000(42001)<br>
    09:35:15.515|.\CallCtrl.cpp(265)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:0403@192.168.75.101:5060><br>
    09:35:15.578|.\CallCtrl.cpp(374)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(1): Calling: VoIPline:403@(Ln.10000@Kebu)@[Dev:sip:xxxxxxx@sip.kebu.it:5060]<br>
    09:35:16.109|.\SLServer.cpp(618)|Error1|MediaServer|MediaServerReporting::STUN:[MS101003] C:1.2: Possible firewall problem. Address mapping failed on STUN server 69.0.208.27:3478 for local address ":9000"<br>
    09:35:16.109|.\SLServer.cpp(674)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210006] C:1.2:Offer provided. Connection(by pass mode): 192.168.75.41:42000(42001)<br>
    09:35:16.359|.\CallCtrl.cpp(182)|Log3||CallCtrl::onAnsweredCall:[CM503002]: Call(1): Alerting sip:xxxxxx@sip.kebu.it:5060<br>
    09:35:16.359|.\CallLeg.cpp(728)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:1.2<br>
    09:35:16.359|.\SLServer.cpp(674)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210001] C:1.2:Answer received. RTP connection: 194.244.11.18:51618(51619)<br>
    09:35:16.359|.\Line.cpp(1108)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Kebu] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [kebuIPPBX] Transport: [sip:192.168.75.101:5060]<br>
    09:35:16.375|.\SLServer.cpp(674)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210007] C:1.1:Answer provided. Connection(by pass mode): 194.244.11.18:51618(51619)<br>
    09:35:16.375|.\CallCtrl.cpp(494)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(1): Device joined: sip:100@192.168.75.41:5070;rinstance=1c48fc187f119742<br>
    09:35:16.375|.\CallCtrl.cpp(494)|Log2||CallCtrl::onLegConnected:[CM503007]: Call(1): Device joined: sip:xxxxxxx@sip.kebu.it:5060<br>
    09:35:16.843|.\CallLeg.cpp(397)|Log5||CallLeg::onConfirmed:Session 39 of leg C:1.1 is confirmed<br>
    09:35:25.562|.\Call.cpp(723)|Log2||Call::Terminate:[CM503008]: Call(1): Call is terminated<br>
    Thanks.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Your static port mappings are not configured or not configured correctly, that is why you are getting warnings....
  3. AlGreen
    Nov 11, 2008
    Can you take a look at this link?
    I did exactly as written there, isn't it the right way to do?
    Thanks.
  4. AlGreen
    Nov 11, 2008
    Ok i did myself, ty
