problems with direct sip calling
Discussion in '3CX Phone System - General' started by beaver, Nov 7, 2007.
  1. beaver
    Aug 2, 2007
    30
    Hi, I have to say that i'm not an expert in dns servers. We want to use direct sip calling feature and for that pourpose we get a dominio that is parked on the servers of the provider. We set up the dominio on the 3cx but when the call reaches the pbx says:
    CM102001]: Authentication failed for SipReq: INVITE 116@xxxxvoip.info tid=0a000024000000f1473103f2000054540000001c cseq=INVITE contact=10.0.0.54 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    Please help.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Which version of 3CX PBX do you use?
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi beaver,
    Please take a look at this URL
    http://www.3cx.com/support/sip-dns-configuration.html
  4. beaver
    Aug 2, 2007
    30
    i'm using the last build
    First of all thanks for the advices. By now it looks that is working sometimes yes and sometimes not. But when it works works perfectly. I'm not shure if it's my server or is the 3cx the one that is not answering. I'm going to tell you the results of our test. By the way congratulations for your great work. 3cx people.
