Problems with hanging up
Discussion in '3CX Phone System - General' started by yaro, Aug 27, 2009.
  1. yaro
    Jun 11, 2008
    38
    When I call someone from my soft client an the phone rings for quite a wile I try to hang up but I'm not getting disconnected at that time. The status is still orange indicating that my extension is in use even if I exit the client and then start it again. While it happens I can make another call and then sometimes I'm ending up with two of them connected which is really annoying. How can this be fixed?
    yaro
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Can you tell us some more about your setup? Network/Hardware/OS
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Try going to the Extensions in the PBX.
    Extensions > Extension XXX > Other >
    Disable Supports Re-Invites and Disable the other Ticked Option.
    Now Enable the PBX Delivers Audio Tick Box. This should be the only Ticked box.
    Save settings and try making a call.
  4. yaro
    Jun 11, 2008
    38
    Thanks LeonidasG but this is exactly how my extension is set up.
    As to my OS it's XPpro but I doubt it's of any help. I use soft client v. 7.0.4526.0 which is not the most recent one but it new enough to have this kind of problems sorted so again don't think this is where the problem lies.
    yaro
  5. LeonidasG
    Nov 19, 2008
    1,406
    81
    Are you talking about Version 7.0 of the PBX?
    If so, i'd reccomend you try Version 7.1 or Version 8 which are currently available to download through these links.
    We made some fixes regarding to some issues with Phone Calls not Hanging up in many cases.
    8.0 Will have these problems Resolved, but i cant be sure if 7.1 has these problems resolved.
    7.1
    http://www.3cx.com/downloads/3CXPhoneSystem71.exe
    8.0 PBX Beta
    http://www.3cx.com/downloads/3CXPhoneSystem8_8637.exe
    V4 Voip Phone Beta
    http://www.3cx.com/downloads/3CXPhone4.msi
  6. yaro
    Jun 11, 2008
    38
    The phone system is 7.1 it's my soft phone client that's v. 7.0. Thanks
    yaro
  7. yaro
    Jun 11, 2008
    38
    Any one knows at least how to force a hang up?
    yaro
  8. LeonidasG
    Nov 19, 2008
    1,406
    81
    The only known way is to go in the PBX select the connected Extension and press Disconnect.
  9. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please provide the logs which are describing the problematic call (better in verbose mode)?
    Thanks in advance
