Problems with incoming calls (12289)
Discussion in '3CX Phone System - General' started by juniorloureiro, Dec 4, 2013.
  1. juniorloureiro
    Nov 5, 2013
    Hello, I have a grandstream 4108 and 3cx v12.
    7Lines are connected on the GS and all day I receive a error email saying that:
    All lines are configured to call a Ring Group. I already tryed to create one more ring group to separate those lines.
    I dont know what am I doing wrong.
    Log:
    Code:
    04-dez-2013 09:59:44.312	Leg L:313.2[Line:10006>>0151532194822] is terminated: Cause: BYE from PBX
    04-dez-2013 09:59:07.641	Leg L:321.1[Line:10006<<unknown] is terminated: Cause: BYE from PBX
    04-dez-2013 09:59:00.124	[CM503007]: Call(C:321): Line:10006<<unknown has joined, contact <sip:10006@192.168.2.102:5070>
    04-dez-2013 09:59:00.123	L:321.2[EndCall] has joined to L:321.1[Line:10006<<unknown]
    04-dez-2013 09:58:59.924	[CM503025]: Call(C:321): Calling T:EndCall:EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=d667bcc7d7df3165] for L:321.1[Line:10006<<unknown]
    04-dez-2013 09:58:59.911	[CM503019]: Call(C:321): Rejected! Line is 'Busy' because number of simultaneous calls per line Line:10006<<unknown is limited by Administrator
    04-dez-2013 09:58:59.911	Line limit check: Current # of calls for line Lc:10006(@granstream[<sip:10006@192.168.2.102:5070>]) is 2; limit is 1
    04-dez-2013 09:58:59.908	[CM503012]: Inbound office hours rule (unnamed) for 10006 forwards to DN:80
    (and sorry about my english, I'm from Brazil, and my resseler can't give me informations)
  2. mlump
    mlump New Member
    Feb 24, 2012
    113
    The open port on your grandstand could be the cause, If 10006 is the corresponding Trunk in 3CX then you need to click on 10006 and check the check boxes at the bottom to disable incoming and disable outgoing calls for this trunk. This will prevent 3CX from attempting to use it.
