- Joined
- Nov 6, 2009
- Messages
- 29
- Reaction score
- 0
Hello there,
I have 3cx pro16 version 8 and just tried to install the mv-374. Outgoing does not goes via the Protech but stays going via the normal trunk. Any ideas?
Incoming is the call after 1 ring automatically ended en is not going through the 3cx. any ideas?
I configured the mv-374 using the info mentioned in the gateway providers of 3cx.
Code:
09:25:13.203 [CM102001]: Authentication failed for SipReq: INVITE [email protected] tid=1d2a2c5d36 cseq=INVITE [email protected]:5060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
09:25:13.203 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.128.130:5060;rport=5060;branch=z9hG4bK1d2a2c5d36
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: "+31644353898"<sip:[email protected]>;tag=110ea1e1
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, CANCEL, ACK, BYE, NOTIFY, REFER, OPTIONS, INFO, MESSAGE, UPDATE
Proxy-Authorization: Digest username="10013",realm="3CXPhoneSystem",nonce="414d535c0181ace824:6e8a7f432d7b5502efd91101862e8448",response="06c6c8818d5937f11652a6ef08918eea",uri="sip:[email protected]",algorithm=MD5
Supported: replaces
User-Agent: Mv-37x (904290)
Content-Length: 0
09:25:13.203 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE [email protected] tid=1d2a2c5d36 cseq=INVITE [email protected]:5060 / 2 from(wire)
09:25:12.984 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Via: SIP/2.0/UDP 192.168.128.130:5060;rport=5060;branch=z9hG4bKa204b69ba6
Max-Forwards: 70
CSeq: 1 INVITE
Supported: replaces
Content-Length: 0
09:25:12.984 [CM302001]: Authorization system can not identify source of: SipReq: INVITE [email protected] tid=a204b69ba6 cseq=INVITE [email protected]:5060 / 1 from(wire)
