Problems with Provisioning and HP switch VoIP
Discussion in '3CX Phone System - General' started by sistemas@maderkit.com, Nov 17, 2017.
  1. sistemas@maderkit.com
    Jun 27, 2016
    With this new version
    When the phones are new, the HP switch VoIP technology works correctly, but when we provision the phones the console is making the HP switch VoIP not work. It does not allow you to dectect the mac from the phones and send it to a VLAN that is not for them.
    Additional when a phone is provisioned with an IP for example 192.168.1.5 when the ip is changed to 192.168.2.10 the phone does not work and the console detects it as a new phone.
  2. Aram
    Aram Support Team
    May 7, 2012
    154
    30
    Please check this post, probably you have the same issue in your network:
    https://www.3cx.com/community/threads/yealink-t46s-boot-loop.51856/#post-212531
