Problems with terminal server
Discussion in 'Windows' started by m.serraglio, Feb 15, 2008.
  1. m.serraglio
    Feb 15, 2008
    7
    i have install 3cx softphone in one server terminal server 2003 rc2 ....
    the software works only with one persone ...
    IS THERE SOMETHING THAT I MAKE WRONG, OR THIS SOFTWARE DOESN’T WORK WITH MORE THAN ONE USERSIMULTANEOUSLY?
    Marco Serraglio
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    I have the same problem. Only with the latest beta.
  3. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    What do you use as a TerminalService client? Is it a thin client?
  4. matthijsolislagers
    140
    Yes it is. But I don't think it matters..
  5. bluefox8080
    Oct 28, 2007
    181
    It should not matter..
    However, it is interesting that you would want to run it on a thin client.
    I am very interested in this scenario.
    How many thin clients doe you have?
    I am not sure any SIP based solution will work with this setup, because it will mean that all VoIP software clients will share the same IP address.
  6. matthijsolislagers
    140
    There are ten thin clients. With the previous version of the VOIP client it worked fine. I only use the VOIP client in desk phone mode.
    The same IP shouldn't be a problem. All users log on with their own extension
  7. Ralph
    Ralph Member
    Jun 28, 2007
    417
    I have attempted to use the new 3CX VoIP client on terminal servers as well.
    The software will only allow one user at a time to use it on the terminl server.
    The older client (3CX Call Assistant) worked fine on terminal servers with multiple clients logged in.
    Anyone know of a fix or work around for this?
    Is there a patch planned or in existence now that will help??
    I love the features of the new client. We just need to have it work in a terminal server environment.
    Thanks again,
    Ralph
  8. matthijsolislagers
    140
  9. aphillips
    Sep 10, 2008
    Did you guys manage to resolve this, spoofing IP addresses on the terminal server wtih a 3rd party product maybe to get around the SIP Phone in a Training Environment?
    Regards, Tony
  10. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    What happens if the different users specify a different SIP port and RTP ports to listen on? Just wondering if this is becasue the first person binds these ports and then we are toast. What if you had another user change their profile to to use different SIP and RTP ports? Can 2 people use it then?
  11. matthijsolislagers
    140
    Same problem..
    Here is the problem signature:
    Code:
    Problem signature:
      Problem Event Name:	APPCRASH
      Application Name:	3CXVoIPClient.exe
      Application Version:	0.0.0.0
      Application Timestamp:	48870b95
      Fault Module Name:	kernel32.dll
      Fault Module Version:	6.0.6001.18000
      Fault Module Timestamp:	4791a76d
      Exception Code:	e06d7363
      Exception Offset:	000442eb
      OS Version:	6.0.6001.2.1.0.16.7
      Locale ID:	1043
      Additional Information 1:	71f4
      Additional Information 2:	8b40d1654001c5e61b4e410be8981ceb
      Additional Information 3:	9e4d
      Additional Information 4:	182b381cd572d288f739f0a6e9785767
    Read our privacy statement:
      http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
    Note: this only happens when the VOIP Client is started for the second time on the same machine in another user session.
