Problems with Videotron.ca digital telephony
Discussion in '3CX Phone System - General' started by bullan, Apr 25, 2010.
  1. bullan
    Apr 25, 2010
    21
    Is anyone here tried to setup a generic VOIP provider with videotron.ca sip information?
    I have a digital phone from and I it works with their softphone and almoust every softphones available but I cant make it work with 3CX?
    Is anyone succeed?
    10,582
    249
    What does the 3CX log show, a failure to register, or a failure when you try to place a call?
  3. bullan
    Apr 25, 2010
    21
    The register error is 403 Forbidden
  4. leejor
    10,582
    249
    It could be either an incorrect password/username, or, and this has happened before, they have barred the use of 3CX on their network. That can be worked around.
    Have a look at this..http://www.3cx.com/forums/help-with-sipphone-com-not-registering-3254.html
  5. bullan
    Apr 25, 2010
    21
    I dont think is a user agent problem, cause I'm able to connect with eybeam (and a lot of other softphones) for example and the user agent is eyebeam xxxxx.
    I guess it'a a registration process problem cause I have to register with a domain different from the sip server
    In eybeam config I can setup to register with a domain and have outbound calls using the sip server.
    in 3cx config I have only sip server hostname and outbound proxy server hostname variables.
    and the error message it's kinda logic I cannot login to the sip server (403 forbidden), I have to login on domain server first.
    anyway, I'll try all combination.
    keep you updated
  6. bullan
    Apr 25, 2010
    21
    ok, I found the right settings for videotron.ca
    I can make and receive calls but I have he same problem, I dont have ringback on outbound calls. Just silence. The call are actually being initiated and in not a HT problem, cause with same adapter I have the ringback on the same provider.
    I also tried eyebeam and have the same problem.
    when I use the 3cx softphone I have a ringback.
    can anyone help me with some leads? I'm not using any tunnels
