Problems with VPS from Web24.com.au
Discussion in '3CX Phone System - General' started by purpleone, Oct 27, 2009.
  1. purpleone
    Mar 18, 2009
    18
    I'm trying to setup 3CX on a Windows VPS. Here is some info:
    WIndows 2003 64bit
    VPS is running in a Virtuozzo container
    Tried 3CX version 7 and 8
    The problem is with registering with a Voip provider. The version 7 shows the error :
    21:52:21.239 [CM305004]: Failed to find a transport to host 202.147.130.12
    It doesnt matter what provider I try, same error (different IP).
    I've changed the STUN servers, to see if that was the problem.
    Incoming registrations work fine. Phones can register and make internal calls.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    What does the "Local Sip Domain Field" say in the Settings > Advanced section? Is it set correctly?
    Did you try using the Public IP without a stun server?
