Processor type help?
Discussion in '3CX Phone System - General' started by AJ Smith, Mar 28, 2018.
  1. AJ Smith
    Aug 4, 2017
    23
    My main system died, and I'm trying to restore on a laptop until I can buy a new system. It says my processor is not supported when I start to install the latest 15.5.
    This is my processor...looks like I'm good up to 64 call? What am I missing? An i7 should be good, correct? Info attached.
  2. AJ Smith
    Aug 4, 2017
    23
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,091
    165
    what operating system ? as it has to be pro or greater
  4. AJ Smith
    Aug 4, 2017
    23
    Windows 10 Pro...I think I am stuck because it is a 32bit on an x64
  5. 3CXDude
    3CXDude New Member
    Oct 1, 2015
    105
    26
    Correct, 64bit required
  6. pact
    pact New Member
    Dec 16, 2009
    202
    36
    Your processor type is fine, the issue then is that you are running 32bit windows (x86). 3CX Requires 64bit (x64) Operating system.
    So you will need to re-install the laptop's operating system if you wish to install 3CX onto it I'm afraid.
