program to use with SIP client
runneranu
Hi all,
I have downloaded multiple times form 3cx but the installation does not give me the SIP option. :S
Can someone please let me know which download link to use so i can configure my callcentric account?
much thanks,
a
After you have installed the 3CXPhone for Windows you need to create a new account and enter your callcentric details there. I know callcentric has guides how to do this on their website as I use callcentric as well. But to use callcentric with 3CXPhone for Windows you will need to get callcentric account details.
http://www.callcentric.com/support/device/3cx/softphone
Thanks,
Nate
@nate: Thank you
I will download and install 3cx for windows and follow the guides. yes, i found the guide as well. I am at work now and will do this from home.
many thanks, a
@nate:
I installed 3cx but did not get the option to create a new account. do i open the management console or myphone?
These are the choices in the programs list under 3cx
thanks, a
@ nate: on the management console, i am getting this msg
[CM501010]: License Info: Load Failed - Error licence Licence: 27 System: 2
but my 3cx phone dialpad on the computer, says not connected.
what could i be doing wrong??
thanks, a
@nate:
got it!!
i had missed the leading one in the callcentric set up!!
one other question, what is my incoming number? do i have one?
thanks, a
Your incoming number is the one you got from Callcentric. Glad you got it working.
Thanks,
Nate
Hi, I am back!!:(
I have a new laptop and have download the 3cx program. installation was fine but how do i get the softphone?
cant find a shortcut for that.
can you help?
thanks, a
duh! never mind - it was another download!!
thanks, a
Get 3CX - Absolutely Free!
3CX
