Programing 1 button global park
Discussion in '3CX Phone System - General' started by Ben P, Jan 18, 2017.
Tags:
Is this possible?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
  1. Ben P
    Jan 18, 2017
    Hello, We're on V14 3cx, using Grandstream GXP2160 phones. To park a call, at current you have to press ;
    Manually;
    Transfer *00 BLNDTransfer ---- Parked to global extension 0
    Through the BLF, for Shared Park extension 0
    Using the BLF;
    Press line 2, to place line 1 on hold, then BLF -- Shared Park 0, then transfer, then the line to be parked.
    Is there anyway to program this into a BLF to simply, park the call I am on to Shared Park 0, through pressing the BLF key.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @Ben P
    On grandstream phones once you are on a call you need to press transfer and the BLF button and the call will be parked.
    Haven't found a way to park it with one button i am afraid
  3. Ben P
    Jan 18, 2017
    Hello Yiannish,
    From what we've seen the only way to transfer to park is to put a call on hold, then select the BLF, then hit transfer, then select the call that was placed on hold.
    If we do it in the order you stated, which makes more sense to me. We get a 404 not found error.
    We're on V14 3cx...also.
  4. YiannisH_3CX
    May 10, 2016
    4,349
    274
    ok good to know the version you are on. I tested on V15. I will have to test in on V14 and get back to you i am afraid
  5. Mr.OrtiZx
    Jul 25, 2017
    To park a call by just clicking the park key make sure you have this dial plan first {x+|\S\Px|\S\Pxx|\+x+|*x+|*xx*x+}
    Second on the template there is the following value:
    <parkextension>
    <value>1</value>
    Change that value to 9 which mean call park.
    1 mean Busy Lamp Field.
