Programmatically Change Outbound Caller ID on the fly
Discussion in 'CRM / Helpdesk / App Integration' started by igor.snezhko, Jan 20, 2018.
  1. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Hello!
    Our customer wants periodically change his outbound Caller ID from assigned DIDs pool.
    Is it possible to develop some script that makes such change when a user calls a number?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hello @igor.snezhko,
    You can use a CFD app to do that. You create a CFD callflow, and from this app you edit the SIP trunk properties using the 3CX Call Control API.
    Kind regards.
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    Our VoIPTools HTTP API has an enhanced MakeCall method that includes a parameter to override the caller ID.
