Programming Polycom IP7000
Discussion in '3CX Phone System - General' started by jhicken, Nov 1, 2011.
  1. jhicken
    May 21, 2010
    25
    We just picked up a Polycom IP 7000 and I have it all up and running OK.
    I need to know if it is possible to program buttons.
    By default on the display it shows two soft key options (New Call and Dir) with two blank buttons.
    Can I program the other two buttons as shared parks or Speed dials?
    Any help is appreciated. :D
    Thanks!
