Programming VM button to include userid?
Discussion in '3CX Phone System - General' started by RobLloyd, Jul 23, 2007.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Is there a way to program the VM button on the phones to include 999 wait a bit and then dial the VM box #? I'm using SPA-942 phones if that helps any.
    I tried putting in 999,100 but that didn't do anything. I would like to program it so it all you have to do is enter the password.
    Thanks,
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The current version should be unable to do this option. This post may to post at Feature requests.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If you configure you phone to dial 999 then send DTMFs corresponding to extension number and PIN (as requested by Voice Mail DR), it will work. Unfortunately, it doesn't supported by all phones :(
  4. philip
    Jul 25, 2007
    5
    it would be much better is the server would accept a call into the VM system from an extension without requiring the extension number. this is how almost all other voip pbx systems work.
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    That would work too.
