Project inquiry
Discussion in '3CX Phone System - General' started by Rasmus, Jul 12, 2011.
  1. Rasmus
    Jul 12, 2011
    I'm looking into PBX and IVR software for a major project I want to start and I thought you could maybe tell me which 3CX products would be needed for that.
    I want to start a small political polling company in the US, using IVR. The idea would be to hook up a 3CX phone system with IVR software and an autodialer to make SkypeConnect calls to registered voters, using phone numbers from purchased voter lists.
    Would that technically work and do I miss any major things I'd need.
    Thanks,
    Rasmus
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    First, you would need an auto-dialer, there are several available, just google for 3CX Auto Dialer. Second, why Skype? There are more affordable SIP trunk providers available.
  3. Rasmus
    Jul 12, 2011
    So I'd need something like this for an autodialer, right?
    http://www.mdlsolutions.com/Dialer.aspx
    That, plus a 3CX system. The above thing also seems to support IVR, which I'd need to record the poll and allow the respondants to select response possibilities.
    And which providers would be for instance more affordable than Skype? I'm a statistician, so I'm not experienced at all with this, as you can see.
    Thanks for your help!
    Rasmus
  4. willow
    willow Member
    Mar 1, 2011
    471
    It probably depends on what you are wanting to pay for. The skype per month price is pretty reasonable for just outcalling to the us. though people can not call into it. I highyl recommed voip.ms for a metered account. about 1 cent per minte outbound is not to bad.
  5. Rasmus
    Jul 12, 2011
    Yeah, that sounds pretty good. I'm searching for something I can make thousands of outbound calls with relatively cheaply, where most calls would probably be unsuccessful and last just like 5 seconds. So besides the per minute price it would be pretty relevant to know how much the service charges for such a call under 5 seconds or so. The price of one minute, half a minute?
  6. willow
    willow Member
    Mar 1, 2011
    471
    normally they charge in 6 second increments with an unsucessfull call not being charged. meaning that if no one answers then it will not charge. so it would be about .01 cents for that type of call.
