Project request CallDetails2HTTP
Discussion in 'CRM / Helpdesk / App Integration' started by gufmar, Sep 14, 2012.
  1. gufmar
    Jul 28, 2008
    Hello
    Would some VAD developer make an offer to develope the following VAD application?
    For each incomming call (external to internal) the application should make a HTTP request like http://server/folder/script.asp?callingnumber=123456&extension=123
    If the http response contains "Check:KO" it should terminate the call without accepting it, otherwise the call should be forwarded to the internal extension.
