Prompt files
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Sep 17, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Do prompt files only work in .wav format? No mp3? The mp3 files are not showing up in my drop down list, only the .wav files are.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The next release of VAD coming very soon, works with V8 and adds support for mp3 files too.
