Prompt Playback
Discussion in 'CRM / Helpdesk / App Integration' started by len@Arena, Sep 25, 2009.
  1. len@Arena
    Aug 4, 2009
    11
    Could one populate the “audio file name” from a variable rather than by selecting the file from a list?
    Len
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Len,
    No, currently that is not possible. Audio file names need to be set in the designer.
    I'm pretty sure that this is going to be an improvement for a future version.
