Prompt Selection Reporting
Discussion in '3CX Phone System - General' started by dburr, Apr 8, 2014.
  1. dburr
    Apr 8, 2014
    Has anyone been able to find a way to generate reports showing the prompt selection that a caller has made? For example how many callers selected option 1, option 2, option 3. We are running with AA's and digital receptionists.
    Thanks!
