Prompts Set Translate Problem
Discussion in '3CX Phone System - General' started by juls, Dec 22, 2011.
  1. juls
    Dec 22, 2011
    Hi everyone,
    I'm new in this forum, and with VoIP telephony. I installed the 3CX Phone system, and I faced a problem with translating the Prompts Set. I followed step by step manual at http://www.3cx.com/blog/docs/localize-promptsets/ , but the problem is that when everything is done, and I go to the control panel, and change the default Prompt Set with the one that I created, the descriptions remain in English. I saved the SetInfo.xml file in UTF-8 without BOM format .... nothing. I can't understand where might the problem is. If you have any ideas where I might be doing wrong please tell me.
    Best regards,
    Julian
  2. misstake2012
    May 23, 2011
    40
    Try to restart the services
  3. juls
    Dec 22, 2011
    Nope......doesn't work. I've restarted them. And When I Apply the desired prompts set, the description is in English (the language that I copied the Prompts Set)
