Proper way of specifying port for SMTP
Discussion in '3CX Phone System - General' started by hccj, May 19, 2014.
  1. hccj
    May 19, 2014
    21
    I would like to know if there is a proper way of specifying a non-standard port for SMTP in the 3CX mail server configuration?
    Apart from that, if anybody from 3CX is listening; it would be great to have a button by the configuration to instantly send a test email by clicking.
  2. roland_3CX
    roland_3CX Support Team
    Mar 28, 2014
    131
    7
    Hi Hccj,
    The forums are always monitored.You may post your questions/concerns at any time, and we will respond in a timely manner. Regarding the email test button, Thank your for the suggestion, I will make sure to forward your Idea. You may also submit that feature at http://www.3cx.com/ideas.
    There are two ways to specify a non-standard port for SMTP in the mail server configurations.
    Method 1 :
    Navigate to mail server tab and for the mail server field, type in the colon symbol followed by the port number (no spaces)
    EX: smtp.contoso.com:25
    Method 2:
    Navigate to Custom Parameters. Settings >> Advanced >> Custom Parameters and search for MLSRVPORT
    Change apply the port number to that name and click apply.
