Proper way to have 2 outbound routes, having issues
Discussion in '3CX Phone System - General' started by L Monroe, Dec 20, 2017.
  1. L Monroe
    Dec 20, 2017
    12
    Hi everyone,
    I want a way that if I press *8 before a number it will show one caller ID, where as other calls that are normal to 7, 10 or 11 digit lengths use our primary SIP Trunk. I added both SIP Trunks and configured them, and put the outbound route for the *8 one on top, setting it to then strip 2 digits, and then below that I have the 2nd outbound route for 7,10,11 digits.
    If I dial *8 first it works as expected, however dialing normally always says forbidden. Am I missing something? Should it not go to outbound route #2 if I'm not dialing *8 before a number? I have it set up like the screenshot below, would appreciate any assistance!
    https://imgur.com/a/TeQUO
    10,737
    278
    Are you attempting to use the same provider/registration for both routes? What does the 3CX Activity Log show for a call that fails?
  3. viraltechnology
    Mar 22, 2015
    39
    6
    The rules are evaluated from top down. whats happening is your 1st rule checks to see if the dialed number starts with *8 if it does it routes it to that voip provider. if it does not ( as the case when you dont use *8) it looks and says nope that call is blocked. switch the order of your rules
  4. vizualpro
    Jul 9, 2016
    88
    15
    As @viraltechnology said the rules are top-down, however it will continue moving down the rules in search of a match regardless of whether the first one is a match or not; so changing the order won't help you here.
    It sounds like there may be an issue with the trunk associated with that rule. If you use the same trunk that you have on your *8 route, does it work? If so, then you will need to check the registration on the one that's giving you trouble.
    viraltechnology likes this.
  5. viraltechnology
    Mar 22, 2015
    39
    6
    i wish i had two seperate trunks to play with on my demo. sounds like an interesting issue.
