Propose to change the default port number, 888, used by Fax Server
Discussion in 'Ideas' started by roamermob, Nov 30, 2016.
  1. roamermob
    Nov 14, 2016
    Hi there
    I would like to know if it's possible to change the default port number, 888, used by Fax Server to a different port.
    Reason for it is, 888 is considered prosperity / luck in Chinese culture and in many cases would be used as an extension number for senior executives such as CEO.
    Is it possible in the future, would 3CX consider to have an option in configuration for to change the default port number used by Fax Server to a different number of our choices?
    Thanks.
