Protocol error layer 2
Discussion in '3CX Phone System - General' started by pj, Apr 18, 2007.
  1. pj
    pj
    Apr 18, 2007
    I need your advice, I am using the 3CX phone to access a VoIP Centrex service from Entacall. When I set up the phone on my laptop at work it works fine and when I set it up on my home computer it works fine (when the xlite didn't). :D
    However, when my customer sets up it on his home network he gets a Protocol error layer 2 error. I have got him to forward to TCP & UDP on port 5060 which the service uses and I really don't know why it is not working. :?:
    He is using a Netgear Wireless modem router.
    Any advice would be greatfully received.
    Paul
  2. Anonymous
    Anonymous Guest
    Honestly, you have to provide more information.
    First Layer 2 does not really relate to the TCP & UDP issue you list.
    Questions:
    is you custoemr on the same service provider?
    is you customer using VPN
    is your customer part of a VLAN
    is your customer using ATM (AAL2 to be more specific)
    is your customer going from a layer 2 into a layer 3 clowd
    See several questions.
    On top of my head,
    I think it is a VLAN issue, meaning that there is a distrubance between A, B and C. (trying to make a Layer 2 switch into a layer 3 switch) the broad casting can stuff up.
    Have a look at his IP router/switch perhaps reboot will help. But I am pretty confident the VLAN routing is buggerd, but without more info it is hard to tell.
    YOu might be a little on your own here, as I do not think it 3CX related it is transport (or osi (how was that layer stack called again)) related.
    Hope this helps.
