Provider registered, unable to make outgoing calls
Discussion in '3CX Phone System - General' started by Kinjutsu, May 21, 2008.
  1. Kinjutsu
    May 20, 2008
    7
    Hi, i'm hoping someone can help me figure this out. I currently have my VOIP provider registered as well as 1 extension (mine), but I cannot make outgoing calls, I keep getting a "408 Request Timeout, internal" error. I have looked around the forum and have not found any answer on this. Here is the log:
    I downloaded X-lite and set it up with the same settings and I can call out just fine.
    Also having an issue with incoming calls, even with my extension registered and not in use, the server keeps saying it's "busy" and forwards everything to my voicemail (as it is configured to do that if the line is busy). Any help with this would be greatly appreciated.
    Thanks.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Has 3CX PBX resolved your external IP?
  3. Kinjutsu
    May 20, 2008
    7
    Where do I check to see if it has?
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Server status page or 3CXPhoneSystem.log
  5. Kinjutsu
    May 20, 2008
    7
    Finally found my problem, it had to do with my outbound rules. Quite simple actually, just something I overlooked. Thanks for the help.
