Provider support (forward original caller id)
Discussion in '3CX Phone System - General' started by amygoda, Mar 16, 2011.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I tried callcentric and inphonex and they cannot forward original caller id
    any idea which provider can do?
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Sipphone was support it
    any idea
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    voicetrading.com
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    No, voicetrading.com does not support id control
  5. eagle2
    Apr 27, 2011
    1,085
    11
    Strange,
    for me it's working. The format should be E.164 (full international number like: 13023849786).
    Try also: siptraffic.com -- you must fill static IP table for access to service (your 3cx server external IP address), then you can send original caller-id.
    Regards
