Provision B601 VOIP Card (T1/E1 + 4 FXO + 1 FXS) with 3CX
Discussion in '3CX Phone System - General' started by lukaksp, Jan 21, 2013.
  1. lukaksp
    Jan 16, 2012
    BACKGROUND
    The Sangoma B601 Hybrid Voice Card with T1/E1 + 4 FXO + 1 FXS is about $850 and is ideal for Small Businesses to harness VoIP with FAX and 4 Analogue lines.
    ISSUE
    How can you provision Sangoma B601 with 3CX
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Re: Provision B601 VOIP Card (T1/E1 + 4 FXO + 1 FXS) with 3C
    Install Netborder and manually install/configure. I am not aware of any template/shortcut, however, as I recall 3CX does not support hybrid gateways (does not mean that it will not work).
