provision phonebook to IP phones with more numbers than only mobile number
Discussion in 'Ideas' started by sed74, Jan 14, 2016.
provision phonebook to IP phones with more numbers than only mobile number 5 5 18votes
5/5, 18 votes
  1. sed74
    Jan 12, 2016
    Customizing Phonebook XML
    It would be very useful to be able to customize the Phonebook generated by 3CX, in order to have a more flexible provisioning set of files.
    We're currently running 3CX v14 with SNOM D715 phones, and the phonebook synchronization is pretty lousy: only one number per contact is synced, and if the first phone number field in the 3CX phonebook is empty, the contact is not synced at all.
    Plus, only ONE XML is produced for every phone brand, and it obviously tailored to the less performing phone of that brand.
    So it could come in handy to be able to customize the XML file the 3CX produce with the phonebook entries, in order to take the most out of each phone.
    Thanks.
    Kongo and Peter Schaefer like this.
  2. aliecom
    Nov 25, 2015
    Re: Customizing Phonebook XML
    I was about to post this idea too because managing Snom phonebook is really painfull with v14.
    I would add to sed74's list of features to improve the ability to manage group (colleagues, VIP, support, etc.) within 3CX because a contact is always inserted in the 3CX generated XML file with the type = colleagues by default. Thus, colleagues group ringer apply instead of the user's identity ringer.
    To get multiple phone number per contact, we need to manually edit the XML file and use the types "MASTER" and "Alias" but that's not easy and it's time consumming.
    Thanks a lot.
  3. das
    das
    Dec 8, 2015
    14
    At this time only mobile no. (+ first/last name) is provisioned to IP phones.
    Most IP phones support more than one phone number for each entry.
    It would be great to provision more than one column (at this time only mobile no.) and to have an option to select the phone no. columns which will get provisioned to the IP phone.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,325
    253
    It would be great to even pull Mobile Numbers from the Extension list (checkbox: Publish Mobile to Phonebook - ADMIN FEATURE ONLY)
    Right now - when I add a new extension I have to add their cell phone separately to the Phonebook.
  5. solutionsit
    Nov 25, 2014
    62
    5
    What kind of ip phones do you use?
  6. das
    das
    Dec 8, 2015
    14
    This depends not on the IP phone (I use Fanvil), support told me, for all (except 3CX clients) only the first phone no. (standard mobile no.) gets provisioned (check the phonebook files for provisioning).
  7. r.towle
    Apr 11, 2013
    67
    10
    I think the 3CX phone book needs a good rethink. Most people these days have 2 or 3 numbers: mobile, DDI, main office number, home phone etc....
    In the current setup, you would need to add 4 different contacts in the 3CX phone book.
    Also - I think the phone book could benefit from having "prepend all entries with '9' (or whatever you prepend for an outside line...)
  8. actbig
    Nov 20, 2015
    24
    9
    don't know why this idea hasn't 100% votes and the issue consist since version 12.
    Somthing has to change whith the phonebook. No matter what device you use whether snom or yealink, the Problem is the same. Only Mobile number is a joke. Please fix this!
  9. Arnaud PENSU
    Mar 10, 2017
    14
    hi everyone,
    another problem is if we indicate only Company name and tel. number, the phone won't see the contact. big problem.
    everyone here, you have to vote on this thread, not only grumble. 3CX won't act if there is no vote.
    saxe likes this.
  10. tvdir
    Feb 17, 2017
    62
    15
  11. teichhei
    Oct 11, 2009
    29
    +1, just have a customer who can't use the client due to no on site server due to push to the cloud and now not even the phonebook works properly.
    #11 teichhei, May 22, 2017
  12. HH60
    Nov 29, 2016
    16
    5
  13. telis
    telis New Member
    Aug 13, 2007
    158
    23
  14. dake
    Aug 28, 2009
    15
    +1 on this
  15. Kongo
    Aug 5, 2018
    7
