Provision Yealink T4x phones in 3CX V11.
Discussion in '3CX Phone System - General' started by johandezwaan, Mar 6, 2015.
  1. johandezwaan
    Nov 13, 2013
    14
    we are trying to setup an Yealink T46g phone with our V11 sp4 phone system, but there are no provisioning templates available.
    can we get those elsewhere or are they coming anytime soon?
    Kind regards,
    Johan de Zwaan
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Am not certain, but have you tried the looking in the update section of 3CX and seeing is a download in the phone provisioning setting is available?
    Also, is your maintenance still in-force?
  3. jasit
    jasit New Member
    Feb 12, 2013
    169
    I can send you a copy of my template if you like
    its for a T46, I built it for v11, I can't upload it says it was rejected because the uploaded file was identified as a possible attack vector. Weird.
    jasit
  4. johandezwaan
    Nov 13, 2013
    14
    there are no updates to install in the management console, and we do have an active maintenance contract.
    @Jasit I would like to receive your template. can you attach it as an txt or zip file?
    Thanks in advance.
  5. jasit
    jasit New Member
    Feb 12, 2013
    169
    Linekey.1 is setup for my dndstatus button, that will need to be changed
    I use a local addressbook, AutoDST for daylight savings time and DialNow and DialPlan
    ## Local Contact/DST Time/Dialnow Rule/Replace Rule ##
    #Before using these parameters, you should store the desired resource files to the provisioning server.
    #For more information, refer to Yealink SIP-T2xP IP Phone Family Administrator Guide.
    local_contact.data.url =http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/T46_contact.xml
    local_contact.data_photo_tar.url =
    auto_dst.url =http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/AutoDST.xml
    dialplan_dialnow.url =http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/DialNow.xml
    dialplan_replace_rule.url =http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/DialPlan.xml
  6. johandezwaan
    Nov 13, 2013
    14
    Hello Jasit,
    Thanks for the XML file. it worked like a charm.
    I've modified the file to enable the super search and directory search functions, an absolute must in my opinion.
    If you are interested in my changes let me know and i'll post my config.
  7. jasit
    jasit New Member
    Feb 12, 2013
    169
    Sure, what does super search do?
  8. johandezwaan
    Nov 13, 2013
    14
    The Super search enables you to search the remote phonebook directly from the phone (much like your cell phone does)
    Ive placed the attached xlm's in C:\ProgramData\3CX\Data\Http\Interface\provisioning and changed the following lines in your XML: they are there by default so just look them up.
    Code:
    #Configure the access URL of the directory setting file.
    directory_setting.url = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/Directory_setting.xml
    Code:
    ##                                   Super Search URL                                ##
    super_search.url = http://%%pbx_ip%%:%%pbx_http_port%%/provisioning/super_search.xml
    Code:
    #Enables or disables the IP phone to query the contact names from the remote phonebook when receiving incoming calls; 0-Disabled (default), 1-Enabled;
    features.remote_phonebook.enable = 1
    #Set the interval (in seconds) for the phone to update the information of the remote phonebook. The default value is 3600.
    features.remote_phonebook.flash_time = 7200
