Provisioning a Grandstream HT502
Discussion in '3CX Phone System - General' started by coreybrett, Apr 13, 2013.
  1. coreybrett
    Apr 12, 2010
    72
    I know v11 has support for provisioning an HT702, is there any chance that would work for a HT502 device?
    11,105
    329
    There may be enough differences in the two devices, that, even if it accepted the file, some (most?) settings won't take properly. I can't see you loosing anything but your time trying, it may just require a reset to default settings to correct any changes that are made.
    You may eventually have to manually provision the unit.
