Provisioning File
Discussion in '3CX Phone System - General' started by donbru01, May 27, 2015.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi at all , we have changed Public IP and we have reconfigured all data on 3cx
    But we have found that on provisiong file for 3CXPhone8 below string retain old ip address
    217.220.38.184:5001 is old ip address , where i can set new ip address ?
    <MyPhoneServerPublicSSLAddr>https://217.220.38.184:5001/MyPhone/MPWebService.asmx</MyPhoneServerPublicSSLAddr>
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    You have to recreate/update all provisioning files.
    This is very easy to do…
    In 3CX go to Settings > Phone Provisioning > Daylight Saving Time
    Enable (or disable) “Enable Daylight Saving Time”, click “Apply”, revert previous setting, click “Apply”, “OK”.
    Now all phone provisioning files are updated with the current settings.
    Hope this help.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi Complex thanx soo much for your help , we have do this fix , but i haven't changed ip address
    Same 217.220.38.184 not new ip :O
    <ProvLink>http://10.10.4.203:5000/provisioning/kmp3s0qsos/TcxProvFiles/3cxProv_141204125137_2438.xml</ProvLink>
    <ProvLinkExternal>http://webrtc.axitea.it:5000/provisioning/kmp3s0qsos/TcxProvFiles/3cxProv_141204125137_2438.xml</ProvLinkExternal>
    <MyPhoneServerLocalAddr>http://10.10.4.203:5000/MyPhone/MPWebService.asmx</MyPhoneServerLocalAddr>
    <MyPhoneServerPublicAddr>http://webrtc.axitea.it:5000/MyPhone/MPWebService.asmx</MyPhoneServerPublicAddr>
    <MyPhoneServerLocalSSLAddr>https://3CXCITDC.AXITEASPA.LOCAL:5001/MyPhone/MPWebService.asmx</MyPhoneServerLocalSSLAddr>
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    391
    53
    If you change your external IP address it doesn't update everywhere. 3CX Training says have to backup your configuration, uninstall and re-install. Then using the wizard put in the new IP address and restore your configuration.
    This is why 3CX recommends using a FQDN instead of static IP address whenever possible. That way if the IP address changes you just update DNS instead of having to do the above steps.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    I noticed this happened to me at my last job - and I went into the advanced parameters and looked for all Public IP instances and manually changed them. Worked fine and no downtime to backup and restore.
    (Of course.... you should probably listen to 3cx.)
  6. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Thanx at all , in all 3CX configuration we have check and i haven't this ip !
    I have found via backup this file .ini
    iiswebsitename=3CX Phone System Web Server
    httpsport=5001
    ippbx=127.0.0.1
    sslfqdnext=217.220.38.184
    sslfqdnint=3CXCITDC.AXITEASPA.LOCAL
