provisioning files does not update on change
Discussion in '3CX Phone System - General' started by standby, Aug 5, 2016.
  1. standby
    Aug 5, 2016
    Hi all,
    I'm aware that files doesn't get created anymore and are generated on the fly.
    I have copied a template and made some changes in notepad and saved it. but these changes are not in the generated document I currently get from the server. When I view the template under settings - templates, the changes will be displayed correctly. What am I doing wrong?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    under extension did you change the device template?
    when you click on the link in the same place, does it show correctly?
  3. neville
    neville New Member
    Apr 23, 2012
    226
    42
    Go to services.msc and restart the management console service and then re-provision.
  4. craigreilly
    Feb 1, 2012
    3,575
    305
    I heard that from someone else - but didn't have to do that.
    And if that is the correct way - how is this ZERO MANAGEMENT?
    More hands on than v14 <
  5. neville
    neville New Member
    Apr 23, 2012
    226
    42
    I spent a lot of time this week testing several ways to try to do it differently. I found the following:
    A change to the template requires a service restart and re-provision.,
    A change to the setting to the phone or blf's under the extension works with just a reboot of the phone. It might update without the reboot if you wait long enough, but I have been to impatient to way very long.
    If anyone finds something different, I would like to see it.
    Chuck
