Provisioning files not created
Discussion in '3CX Phone System - General' started by trident25, Aug 2, 2016.
  1. trident25
    Jul 28, 2016
    Hi Guys,
    I've installed a fresh copy of v15 and then upgraded to the latest SP1 but I'm having a problem provisioning a Cisco 7941.
    Once the phone is configured under an extension the SEP* file isn't created in the provisioning folder. The provisioning looks to complete OK through the web interface.
    Are there any additional logging locations with 3CX that might have some further information?
    I'm on v15.0.56772.0 running on Server 2012 R2.
    Thanks,
    Stu
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,956
    179
    I have been told the Web Engine creates the file on demand only. It does not sit there infinitely as it did in v14 and prior.
    Hope that helps...
  3. andreaschr
    andreaschr Support Team
    Oct 26, 2015
    93
    6
    Hi craigreilly ,
    Did you follow this guide ?
    http://www.3cx.com/sip-phones/cisco-7940g-7960g/
    Yes you are correct we are generating the files on the fly .
    In additional to the guide you need to download the config file and place it in the provisioning folder or in the folder you pointing the cisco to get the file .
    From Management Console edit the extension that you configure the cisco go to Phone Provisioning Tab and download the Provisioning Link.
    You will download the config file that it will look like this SEP_MAC_.cnf.xml. Then place this file to the folder you pointing the cisco to get the configuration.
  4. trident25
    Jul 28, 2016
    Hi Both,
    Thanks for the clarification. I had worked out that I could just download the file manually and place it in the directory. To be honest this feels like a backward step as far as provisioning is concerned. Can I ask why the files are no longer automatically created in the provisioning directory?
    I'm guessing that the non Cisco phones are able to use the URL for provisioning? Is this a subtle move by 3cx to migrate people away from using Cisco phones?
    Thanks,
    Stu
  5. craigreilly
    Feb 1, 2012
    2,956
    179
    I'm not actually having any issues - just responding to the OP.
  6. Aram
    Aram Support Team
    May 7, 2012
    86
    18
    Hi guys,
    To provision the Cisco 7941 and 7961 you need to the following steps:
    1. Install and configure TFTP Server ( http://www.3cx.com/sip-phones/tftp-server/ );
    2. Point it to any folder;
    3. Create the extension on 3CX Phone system with correct MAC address and model chosen;
    4. After the the extension will be created edit it, go to Phone Provisioning tab and click on Provisioning Link URL;
    5. Save the SEPXXXXXX.cnf.xml file in your TFTP folder.
    6. Configure Option 66 to the IP address of the TFTP server ( http://www.3cx.com/sip-phones/cisco-7940g-7960g/ ).
    Start the phone.
    To provision the Cisco 7940 and 7960 you need to the following steps:
    4. After the the extension will be created edit it, go to Phone Provisioning tab, click on Provisioning Link URL and download the SIPXXXXXXXXXX.cnf file;
    5. Copy Provisioning Link URL, replace "SIPXXXXXXXXXX.cnf" with "SIPDefault.cnf" and download that file too;
    6. Move both files in your TFTP folder.
    7. Configure Option 66 to the IP address of the TFTP server ( http://www.3cx.com/sip-phones/cisco-7940g-7960g/ ).
    Start the phone.
  7. Aram
    Aram Support Team
    May 7, 2012
    86
    18
  8. briankayser
    Jul 19, 2016
    49
    5
