Provisioning Line Keys for Some Users Only
Discussion in '3CX Phone System - General' started by TSlocum, Jul 18, 2014.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    3CX v12.0.35528.640 SP.5
    Cisco SPA514g phones with FW 7.5.5
    We have about 30 users in our office, and about 7 or so need an extra extension on their phones. I manually edited the settings on these phones web interfaces. The problem I've been having is that every morning when I come in, the line keys have all reset to 1.
    I found this topic (http://www.3cx.com/forums/cisco-spa504g-will-not-provision-line-key-29152.html) about provisioning different line keys. That looks like what I want to do to get the separate extension to work permanently.
    My question is, is it possible to use this on just a few phones?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    253
    you would best have a second template for these phones.
    -If it is the same extension for each one, then 1 template will suffice. Then select this template under the extension configuration in 3cx.
    -If it is a different extension for each one, then each phone will need a template.Then select this template under the extension configuration in 3cx.
    -The easier method would be to remove the MAC Address from the Extension and change the template line to blank... then they should not autoprovision.
    (I have no experience with Cisco phones... Can you tell them to not auto provision in the web interface somewhere?)
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    When I create a new template, I need to copy Identity 1 and create Identity 4 for the 4th key right? Do I need to create Identity 2 and 3 as well?
    Also, underneath "SIP Settings for Identity 1" is "Audio Codec Settings for Identity 1" and "Network Location Setting for Identity 1". Do I need to copy those and create them for Id 4 as well?
  4. craigreilly
    Feb 1, 2012
    3,321
    253
    I do not have any experience with Cisco... but I would copy all of the items in the profile.
  5. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    I turned off auto-provisioning on the specific phones, and set the 4th line key manually, which seems to be an okay workaround.
    Is there anything I should keep in mind with these phones not auto-provisioning? Any problems I might run into, etc?
